Old 25-11-07, 05:35 PM   #21
Robw#70
Default Re: more horses please
Oh and as to re-maps or power commanders, as a single time thing a re-map will always be a better bet as it sits in the ECU and replaces your original, a power commander is an output modifier, and as such merely modifies the ECU output, although the power commander does allow some changes, which a single re-map won't without a return vistto whereever you got it done in the firstplace (or anywhere else that does it), the Yoshi box is a direct mapping tool and is way better than a power commander, but you don't buy them (loads of money) just pay for their use (alot less than a PC).
(and now comes along the "mine dones 85bhp with it's (please insert whatever slip-on can make you like here) brigade , I'd refer you the the second line down above)
Cheers Mark
The yosh box is old hat now and no way near as good as a pc, you can only adjust low,mid and high wheras a pc is adjustable every 250 rpm at 2/5/10/20/40/60/80/100% throttle openings and if you want to spend the time you can do advanced maps seperate for front and rear cyl.
The is remap software that gets close to the pc but its still limited by the restraints of the std ecu and works the same as the yosh box, just with finds parameters.
Old 25-11-07, 05:58 PM   #22
ThEGr33k
SO... whats a PC appart from a personal computer?
How much can be done with a power commander?
Old 25-11-07, 06:09 PM   #23
Pc is a power commander
Loads, but IMO youll have to spend that much dyno time to actually make use of that extra adjustment that you might as well just buy a gixxer
Old 25-11-07, 06:23 PM   #24
ThEGr33k
PLEASE refrain from swearing on the forums
Im not interested in an IL4 tbh. WHEN will i need to rev an engine like that is my thoughts.
What im looking for is more midrange and getting an IL4 will reduce it so no thanks.
Old 25-11-07, 06:25 PM   #25
You're not going to get that much more grunt out of an SV without seriously silly tuning, like big bore kits etc.
Old 25-11-07, 06:30 PM   #26
fizzwheel
fizzwheel's Avatar
Which is exactly what I did
Old 25-11-07, 06:31 PM   #27
fizzwheel
fizzwheel's Avatar
Depends on the IL4, you really think your SV has more mid range power the an R1, a 10R a Blade or GSXR thou ?
Old 25-11-07, 06:44 PM   #28
ThEGr33k
Yea and i can buy one of those...not. But if you are compairing Bikes like this, im sure a buell 1200 will have a tonne more midrange.
I have the problem of reach (short legs) so most bigger bikes are difficult, the SV thou was tip toes for me! I really like the SV650, but i want some more midrange on it, thats all, the top end is enough to break the law and enough to keep up with an SV thou to 120, which is enough for me.
This is a comparison of the V-twin and the IL4. (I stole the dyno from laser exausts...) this shows what im trying to say. Where do you ride normally? Not above 10k rpm im guessing.
Considering the IL4 is probably more tuned than the SV the SV shows its stuff well.
If i knew for certain the laser 2-2 system did this id be very tempted.
Old 25-11-07, 07:00 PM   #29
fizzwheel
fizzwheel's Avatar
See this is what I just dont understand, you buy and SV, then and exhaust, then and filter then a few hours on a Dyno, then a power commander to set it all up, perhaps some more dyno work, then you mod the suspension...
How much does that all cost... I bet if you added it up, you could have bought a bike with more power, more midrange, and that stops better than your SV does. It to me just doesnt make financial sense, unless your purely doing it because you like fiddling then fair enough.. I dont.
You sure ? looks like a power curve for the same bike with different exhaust on it, rather than a comparision of two different bikes...
Depends. Most of the time no not over 10K, but if I'm having fun its between 6 and 9, if I get a bit carried away then around the 10 to 12K mark, but I have been known to regularly check if the rev limiter is working
Don't get me wrong its an brilliant bike and I really enjoyed my two years on mine, I just dont think its worth spending money on to get more power / midrange out of it, I think its more cost effective just to change bikes.
Old 25-11-07, 07:09 PM   #30
ThEGr33k
There is a pink line there below the SV... have another look .
About the cost. Well exhaust is gunn be bought for pretty much any bike i get, so is a air filter... So they are kinda standard issue i guess. PC will be about £250 setup not sure £60-80 maybe.
Forks, about £300 for all the front end of a gixxer onc breaks and wheel. £300 for a decent rear shocker.
All in about £1000 if im unlucky...
The other great thing is weight. It is about the same weight as a gixxer 6. If i went for a bigger V-twin it would weight a lot more.
I guess i like tinkering If i had the money id make an SV monster (not like the Ducati) one that handles like a dream and goes like a rocket... I dont so im stuck making it handle like a dream and go well
If you don't like horses, look away now... Scooby Drew Photos 14 24-08-06 10:17 PM
Four Horses Tonight 2nd Aug 06 7:30 Stu Guildford Massive 26 03-08-06 10:47 AM
Glue / Horses rpwoodman Idle Banter 7 02-06-06 04:06 PM
Horses Ceri JC Bikes - Talk & Issues 83 08-03-06 08:33 AM
Who has the most horses??? pedrosis Photos 3 17-08-05 04:22 PM
