#21 |
#22 |
![]() Last edited by Blue_SV650S; 07-12-07 at 01:07 PM. |
#23 | |
I'd do it because it makes the bike nicer to ride, not neccesarily the power (though it's nice to have) but also the delivery- the longer peak with the ex cams is the difference between a gear change and not inbetween the bottom of duffus dip and glenvarigill at knockhill, I've found, to give you a wee "real world" frinstance. There's loads of time when being able to hold onto a gear can be a big advantage, even if like me you're not out to knock off seconds it lets me think a bit more about the approaching corner instead of what gear I'm in. I wouldn't call it essential at all, but it's also not stupid. I do agree that there's other things that are better to spend money on, that's why I was recommending suspension, but it's out there as an option and not a bad one, certainly far better than exhaust systems and rejetting for a track bike IMO.
#24 | |
![]() I agree, its a good mod, I just don't think the gain/benefits are great enough to warrant it unless you are getting serious/racing. or you pick a set of cams up for nothing I uspoose... The geeza has already said he doesn’t want to throw money at it … if he was going to spend money at a trackbike he would get a GIXER … that is the logical approach to me … With this in mind, the engine isn't going to get a look-in?? ![]() |
#25 | |
Maybe I should just learn to be faster through the Bus-Stop and carrying a higher gear to start with, then there'd be no real need to do the change half way down the hill. But, my instructor mate tells me that the Bus-Stop is one of my better and faster sections, so I'm not going to push it any further. |
#26 |
£50 for a set of carbed model intakes and a pair of gaskets, not a big investment if it's a bike you're going to take to half a dozen £100 trackdays I reckon. But yep, we basically agree I think, I'm just throwing out options.
You'd definately have to be a bit wrong in the head to scrimp on the suspension in favour of power.. Disagree on the sprockets though, that'll shift where one gear works but it won't make it work on a wider range. Then again, it might be my rubbishness/lack of competetiveness coming through, I suppose though I can make it work through a wider rev range I should probably still be making the shift and staying closer to the peak...
#27 | ||
![]() Oh and as you know I HAVE done the cam swap in my bike (like for like though). Would I do it to another bike* - NO!! ![]() Oh and you forgot one thing ... those cams you buy for £50 will still be worth £50 when/if you want to sell ![]() Finally - you will always have to compromise .. even with the cams ... I have my SV (with pointy cams) on the limiter about 2/3 way down silverstone back straight .... I could 'gear' this out, but I'd loose so much elsewhere, I have chosen to sacrifice a few MPH down the back straight ... Last edited by Blue_SV650S; 07-12-07 at 04:00 PM. |
#28 |
#29 | |
![]() Didn't you do the minitwin-legal full cam swap though? Not quite the same.
#30 |
touché
![]() However, I only bought the cams coz I was thinking of racing the SV - that is when even small HP differences do matter ... I also changed the sprocket ratio front and rear ![]() Last edited by Blue_SV650S; 07-12-07 at 04:15 PM. |
Not A Bike but my track toy :) | Stoneyginger | SV Ecosse | 26 | 11-05-09 09:57 PM |
Getting a track bike. | ThEGr33k | Bikes - Talk & Issues | 94 | 06-03-09 11:32 PM |
Track Bike | 600+ | Bikes - Talk & Issues | 2 | 04-04-07 09:41 AM |
Track Bike | sweepdoggydog | Bikes - Talk & Issues | 5 | 07-11-06 10:50 AM |
Track bike | sv4me | Bikes - Talk & Issues | 26 | 04-08-05 11:39 AM |
