Old 11-01-08, 09:50 AM   #21
Lozzo
Default Re: Front fork clean up
You will never get lacquer to stick to polished alloy...it just won't work. It needs a keyed or painted surface to adhere to, anything else and it'll just lift off as soon as it gets the slightest chip in it.
You'll have more success trying to glue two bits of lard together.
Old 11-01-08, 03:50 PM   #22
scottjames
i know, i do a lot of model stuff and ive had that problem before which is why i just cleaned them up. got em smooth slightly keyed then lackered. i wouldnt spray on a shiney surface. its bound to come off stright away. most people wouldnt think tho ive seen it loads of times.
Old 11-01-08, 04:19 PM   #23
John Burt
I've sucessfully glued lard together - I used butter, mind you it all smelt a bit funny come summer
Old 11-01-08, 04:24 PM   #24
ranathari
Excuse my ignorance but how do you get the forks keyed so you can lacquer them?
Old 11-01-08, 08:34 PM   #25
Lissa
Just Ballast
Lissa's Avatar
Originally Posted by toonyank View Post
Maybe it was the prep or just the cheap Halfords lacquer it just flaked off which lacquer did you use?
Maybe it's time for the Lissa touch
If you lived closer, I'd do them for you
Old 11-01-08, 08:39 PM   #26
GastonJ
can I drop my bike round as well, it's not a pointy!!
Old 11-01-08, 08:42 PM   #27
Lissa
Just Ballast
Lissa's Avatar
Absolutely
Old 11-01-08, 08:57 PM   #28
scottjames
you just leave them slightly rough once you've sanded them, basicly leave them in the stage before you'd polish them, then lacker them instead.
Old 11-01-08, 09:07 PM   #29
GMS
GMS's Avatar
Or whilst at that stage use a primer for alloy give them a few coats of satin black and forget about them
Graham
Old 11-01-08, 09:10 PM   #30
plowsie
you'll wish you'd never said that with me lurking
Or dont you clean Honda's?
Front fork protection Tigerrrr....... SV Talk, Tuning & Tweaking 1 05-07-08 09:44 PM
Front Fork Servicing mattglavin SV Talk, Tuning & Tweaking 25 26-10-07 06:57 PM
Front fork help? Bikerz SV Talk, Tuning & Tweaking 5 25-05-05 03:12 PM
front fork pitting. Silver Dream SV Talk, Tuning & Tweaking 4 22-05-05 11:50 PM
Front Fork Options snoopy SV Talk, Tuning & Tweaking 15 21-01-05 03:16 PM
