#21 | |
#23 | |
Steering like this, even if you could do it properly, is not countersteering, though. It negates the need for countersteering by moving the weight in another way. At no point will the front wheel point in the opposite direction to the way you are pulling the bike over. How easy would it be to fall off if it did! ![]() (post not directed at g2d) Last edited by sinbad; 12-02-08 at 11:32 AM. |
#24 |
I think that's more straffing than turning though. If you bump the wheel out of line by jumping about the bike will change direction but it's not getting the bike to turn - it's like saying the turning circle is 0 if you pick it up and point it the other way
SV650SK3 - GSXR600K2 - GSXR750K6 - ZX636RC1H - HD Sportster 1200 - CBR600F 2012 - GSXR1000K7 - Triumph Bonneville T100 2019 - Aprilia Tuono 660 |
#25 |
Getting back to the actual question:
The only way is would be overdone, is if by flicking the bike one way, and then quickly the other, the suspension gets unsettled, and you could potentially lose some stability. |
#26 | |
So you're riding down the road with no hands on the bars and you can weave the bike very successfully back and forth across the lane. How? By magic? ![]() ![]() Jumping up and down on the footpeg is applying the force very close to the centre line of the bike in a *downward* direction. Moving your body across the bike and stopping this movement using your knee on the tank is in a sideways direction and *will* make the bike move. This will hinge the bike at the forks and it will make the bike move right. The Bike will them compose itself and strighten up due to the rake and trail above and the gyroscopic effect of the wheels (which makes biking possible in the first place). In the video clip of the rider jumping on the pedal above, he's also holding the top of the screen effectively cancelling out the effect of what he's doing. Let's see him doing it again without holding on to the screen. ![]() Newtons laws of motion dictate that for every action there is an equal and opposite action. Jumping up and down on the pedal like that will compress the suspension. Swinging your body to the side and stopping hard against the tank with your knee will have a greater action in a different direction. The gyroscopic effect of the wheels is a very strong force so you need to apply a force great enough to overcome it. The fact that we can weave a bike down the road without touching the bars shows its possible. However we are using an inefficient force to alter the gyroscopic effect. Turning the bars has a much greater effect which, interestingly, is why they are there! ![]() Carl Last edited by Berlin; 12-02-08 at 04:50 PM. |
#27 |
I've had the pillion on my bike steering it before. (terrifying!)
#28 |
Monkey, I wonder whether the reason that you can't lean the Daytona any further without feeling like you'll drop it is because you're not going fast enough at that point to need to do so?
TBH on my gixxer I rarely need to drop the bike down further with a conscious push from the bars, as it turns so easily anyway. The only time I've found the need to do so is for fast changes of direction on track. I should imagine your bike would behave in a similar way, unless the suspension's been adjusted. Incidently, once you've got your tyres warmed up on a dry track, you'd be amazed at how quickly you can throw a bike down for a turn and not lose traction. You can try it out for yourself at the chicane in March! ![]() |
#29 | |||||
Luke |
#30 |
I'm a big fan of steering with no hands on the bars and just seeing how my body weight affects the steering. I can get round a gentle 50 degree bend without using my hands, but I am quite a heavy guy.
At what point... | the_lone_wolf | Idle Banter | 10 | 01-03-09 08:36 PM |
How dangerous is this.... | ooger | Idle Banter | 14 | 09-05-08 12:54 PM |
What is the point of......... | zedleppelin1981 | Idle Banter | 18 | 10-01-07 08:25 PM |
Is biking REALLY dangerous or only midly dangerous? | thor | Bikes - Talk & Issues | 68 | 25-04-05 07:36 AM |
What's the point here? | Thumpa | SV Talk, Tuning & Tweaking | 53 | 18-08-03 09:16 AM |
