Old 13-02-08, 11:20 AM   #21
ASM-Forever
Default Re: have we been poisoned
meeee?
not if I can help it, tis vile that stuff.
You can't drink cheap vodka neat, as it is wank.
The good stuff at the right temperature though is worth checking out if you havn't.
Old 13-02-08, 11:51 AM   #22
On a budget, you're probably better off with carb cleaner.
Definately
Old 13-02-08, 02:50 PM   #23
Pedro68
Originally Posted by mrs24_7 View Post
Co2 leak anywhere???
do you mean carbon monoxide (CO) ? Saying that both are not a nice way to go....
Actually in a pub, you're probably more likely to find CO2 (Carbon Dioxide), as it is (or was when I worked there) used to keep the lager/bitter tanks pressurised. CO2 is denser than air, so it settles on or near the ground, which is pretty lethal because first you'd pass out, and then hit the deck, where the saturation of CO2 would be even greater ... one of the first things I learnt in the trade was to properly ventilate the cellar when de-pressurising the tanks ... and then generally to stay well out of the way for 10 minutes.
But as MissYC says, neither is a good way to go
Old 13-02-08, 03:37 PM   #24
Kate Moss
Im clever and didn't even know it!
Old 13-02-08, 04:14 PM   #25
missyburd
Have had the good stuff too, not bad. still wouldn't make a habit of drinking it neat, would be able to feel my liver frazzling
definitely helps to know these things! And can't deny you knows your stuff Pedro
Old 20-02-08, 03:28 AM   #26
phil24_7
Originally Posted by gettin2dizzy View Post
The lines won't have cleaner in them; it's a big myth. Anyone who works in a bar will be more than aware of the obscene amounts of water pumped through, the fact most bars can never be arsed, and that the stuff they use nowadays is pretty soft.
The big myth is that beer is watered down, now line cleaner is a different matter.
Many things can happen at many different points to allow line cleaner to stay in the lines from machine/equipment failure to human error and believe me when I say beer line cleaner is not mild. If you get it on your skin you can feel it eating your skin away (that slimy feeling is not the cleaner, it's your skin), it'll bleach your clothes easily and if you happen to wipe down the top of toilet cisterns with it, you can make coke heads have serious nose bleeds!
I have had some half-wit at my pub serve a pint of line cleaning solution to a customer as an ale, god knows how he didn't smell it even if the solution was slightly murky!
To answer your question, line cleaner will make your throat very sore as it will strip some of the skin off and can leave it inflamed, how much cleaner you have consumed will determine how bad your symptoms get/got!
Old 20-02-08, 01:56 PM   #27
What a shocking accident, however would that happen.
Old 20-02-08, 04:47 PM   #28
Kate Moss
Is that why I always get nose bleeds in your pub babe?!!!
Old 20-02-08, 05:15 PM   #29
Lol kate moss, who'd have thought it!
Old 20-02-08, 07:30 PM   #30
phil24_7
Tried and tested!!!
Guy was searched and coke found, how unlucky was he that day!!!
Crash.NET - Stoner takes 'poisoned chalice' pole NewsBot News 0 21-07-07 11:40 PM
