Old 14-03-08, 02:52 PM   #21
ASM-Forever
Default Re: To swap or not?
It will pretty certainly need rejetting IMO.
You won't see much benefit power wise without that and it will probably run a bit rough.
I'm more familiar with FI bikes/remapping, however you will prob need a dyno/variety of needles to get the best results. If you have a google you might be able to find the configurations that someone with the same set up used.
Old 14-03-08, 03:04 PM   #22
rictus01
rictus01's Avatar
Na you won't, just swapping the can over , you'll be fine,it won't cause any harm at all and sound awesome.
If you're after power gains and such, then a full system/re-jet/re-filter & dyno time or different bike are worth looking at, and that isn't what the original poster was talking about, but the SV is a good package for what it is and a can just makes it sund as it should, don't mokey around with the air filter, needles/jet's or anything else unless it's done in the spirit of "playing about" as it will return very little.
Cheers Mark.
Old 14-03-08, 03:07 PM   #23
ASM-Forever
Cheers Mark.
i would agree with you, however its a full race system.
Old 14-03-08, 03:13 PM   #24
Twinny
It seems to runn fine?but i'll get it dyno tested and jetted in the future, is it fine to ride for now? or should i do this asap?
Old 14-03-08, 03:17 PM   #25
ASM-Forever
Depends how rich/lean etc it is running. You have to make the judgement for yourself, but IMO there is a possibility that you could knacker your engine.
Its your decision at the end of the day!
Old 14-03-08, 03:21 PM   #26
rictus01
rictus01's Avatar
If it's a standard bike and all you've changed is the can, then it'll be fine and run without any damage to the engine at all, you won't be the first or last to do it.
If you've money to burn or need peace of mind, then feel free, I wouldn't for just that.
Cheers Mark.
Old 14-03-08, 03:25 PM   #27
Sudoxe
Renegade made fantstic cans, all hand made and rebuildable. Grab it whist you can!
Dan
Old 14-03-08, 03:32 PM   #28
Twinny
Cheers Mark.
see its not just the can mate its the full system,the bike is completly standard,thats the thing it seems to run fine, i wouldn't mind taking to do a dyno place for 20-30mins on there and just to be sure and see wat its running,but i don't think theres any round me with stuff like that,SE London/kent, never seen any biek dynos round here
Old 14-03-08, 03:33 PM   #29
Sudoxe
Get the full system then! Jets are cheap!
Old 14-03-08, 03:58 PM   #30
rictus01
rictus01's Avatar
if it's a full system but standard jets and air filter it'll be running a bit rich, few pops & bangs, and consumption will be up a bit, but you won't do any damage, OK you're no maximising the benefits, but if you're happy just use it like that.
Cheers Mark.
Anyone want to swap??? Binky Idle Banter 0 06-08-08 03:16 PM
Anyone want to swap with me... furrybean Idle Banter 20 02-02-07 01:57 PM
Cam swap for K2 suzsv650 SV Talk, Tuning & Tweaking 6 12-01-07 06:57 PM
SWAP!! Marshall Stuff Wanted 6 11-05-06 11:34 PM
oh to swap or not to swap that is the question.. DrPain Bikes - Talk & Issues 27 25-04-05 02:48 PM
