#21 |
Wow, this is deep stuff, thanks for doing the homework!
#22 |
Have you taken the fork caps off yet Drag? Somebody may have already used spacers to add some preload.
#23 |
Yea peter, i stuck new spring and oil in recently in my 01 and there's the standard spacers there, but again there hollow, gonna have to come up with some thing to sit on top of them
#24 |
Spares Direct. The washers are a couple of quid each.
Link to SD is in the announcement section. (top of the Stuff wanted Section) |
#25 |
i'll drop them an e-mail so, i assume there the full washers/spacers ...only one way to find out
#26 |
They are just round discs. No holes at all. Tell 'em you want them for under the preload adjusters and you'll get the right ones.
#27 |
Thanks for the info jester..i shall await there reply
![]() P.s ok im a bling whooreeee what about some nice blue pre load adjusters ...any body got some details on them ? |
#28 |
![]() Last edited by Jester666; 11-06-08 at 08:37 AM. Reason: Bleedin censorship!! |
#29 | |
![]() Money spent now ... Pics soon ...well when this all arrives Last edited by drag; 11-06-08 at 09:20 AM. |
#30 |
When you come to fit your adjusters, with new washers, you will find your spacer tube is too long, you will need to cut that down by about 13mm.
TBH, unless you are either crash dieting/binge eating or carrying pillions. Once set up correctly, you never need to adjust the sag (That is all the preload does). So whilst you are going to all the effort of fitting new adjusters. Put in decent springs designed for English and not Japanese riders. and a higher viscosity oil to aid the damping
Not Grumpy, opinionated. |
Rear Shock Hydraulic Pre-load Adjusters | Luckypants | SV Talk, Tuning & Tweaking | 5 | 31-01-07 05:02 PM |
Pre-Load Adjusters | PaulyMac | SV Talk, Tuning & Tweaking | 4 | 06-12-06 10:44 AM |
pre-load adjusters | jayjay | SV Talk, Tuning & Tweaking | 2 | 17-04-06 03:05 PM |
Pre-load adjusters on a 2000 model | The Wolf | SV Talk, Tuning & Tweaking | 3 | 15-06-05 12:22 PM |
FORK PRE-LOAD ADJUSTERS ON A 'NAKED' | alexb | SV Talk, Tuning & Tweaking | 4 | 21-01-05 09:19 PM |
