Old 07-06-08, 10:24 PM   #21
metalmonkey
Default Re: Bike not running.....not too obvious, opinions required please
I think when my bike was serviced it had to much oil put in, will itdamage the bike or should it drained ect? Thx
Old 08-06-08, 12:29 AM   #22
Grinch
It can do, as it can put to much pressure on the bike internals, though it depends on the amount. If I remember correctly it can get sucked back up into your airbox, and then burnt, so this causes the smoking, and will be bad for the spark plugs.
Old 08-06-08, 10:15 AM   #23
Camel
I have definately learnt that if you have too much oil in your engine, it will get back into the airbox. If you lift the tank, and remove the air filter, it can collect in the bottom.
I found some in there, so drianed the oil a little (ok 2 litres odd), then topped up as necessary.
If your bike is on a paddock stand, then when you top it up to F, and drop it back down, it may need a little more. The bike needs to be level to get a true reading.
Either that, or drain it all and measure it as you re-fil - thats what I'll be doing next time for sure.
Obvious New Item of the Day SoulKiss Idle Banter 7 20-01-09 06:33 PM
Haggling if a bike has no obvious flaws... Bear Bikes - Talk & Issues 64 21-11-07 09:04 AM
Insurance Quote - Opinions required Urgently!! Reh Bikes - Talk & Issues 14 17-09-06 05:00 PM
My first off... Help required tp get the SV running again.. MavUK SV Talk, Tuning & Tweaking 7 30-11-05 08:55 PM
New rider - Black SVs K4 - Opinions required stevelondon1979 SV Talk, Tuning & Tweaking 14 04-11-04 09:19 AM
