Old 02-11-08, 04:12 PM   #21
philbond07
Default Re: Extending the stock shock
Originally Posted by Dangerous Dave View Post
Yeap, you can get 40mm ones too.
I think 30mm@tail would be great; then I could drop the forklegs by 10mm again and still have like 20mm raise left and not upset standard geometry of the bike too much.
Now I only have to find out how much shock has to be raised for that.
Old 02-11-08, 06:47 PM   #22
Dangerous Dave
Do not drop the forks more than 12mm, your front wheel will start to hit the radiator/cylinder.
I also only recommend you drop the forks by 10mm overall if you have the springs and oil changed to suit your weight.
Old 03-11-08, 03:01 AM   #23
Blue_SV650S
Ground clearance is plops as it is ... don't drop the front, raise the rear
Old 03-11-08, 08:22 AM   #24
philbond07
Ha Dave, yes sorry I meant "drop the forklegs" (and raise the front) again so they come back into original position. Thanks for being concerned
Old 03-11-08, 08:23 AM   #25
philbond07
Exactly, That's what I wanna do in the end.
Old 03-11-08, 11:19 AM   #26
Blue_SV650S
Yeah, just put the front back to stock!!
Old 03-11-08, 11:54 AM   #27
philbond07
No kiddin, I could do that, cause I still have the oem springs hanging around .
Just have to find some 0.001W forkoil.
Old 03-11-08, 12:10 PM   #28
Use tap water and a little blended salmon. Should give OEM feel and smell when you replace it.
Old 03-11-08, 01:50 PM   #29
Blue_SV650S
... I meant put them back to stock setting in the yokes (i.e. with only the fork cap showing), not stock springs etc!!
Thinking of reverting back to stock shock ... Blue_SV650S SV Talk, Tuning & Tweaking 31 19-09-08 12:33 PM
Extending the stock shock Blue_SV650S SV Talk, Tuning & Tweaking 1 09-06-08 02:52 PM
Extending the fuse box. Grinch SV Talk, Tuning & Tweaking 5 26-06-07 09:47 PM
GSXR rear shock stock spring rates lukemillar Bikes - Talk & Issues 3 07-05-06 01:38 PM
stock sv1000 shock settings mac650s SV Talk, Tuning & Tweaking 1 26-11-05 09:12 PM
