Old 24-06-08, 10:55 PM   #21
St0rmer66
Default Re: Fork spring replacement.
Ordered some Hagon Springs and 10w fork oil. Came to £62 so I'm happy with that. Should be a worthwhile upgrade along with the rear shock .
Old 24-06-08, 11:11 PM   #22
plowsie
Where from?
Old 25-06-08, 05:00 PM   #23
St0rmer66
That was from intobikes.co.uk . It's Hagon fork oil too, so it matches if you have OCD about that kind of thing!
Old 30-06-08, 10:18 PM   #24
gettin2dizzy
what tools do you need for this?
Does the Hyperpro kit consist *only* of the two springs? (ie no spacers etc?) as I'm looking at a second hand set
cheers
Rob
Old 30-06-08, 10:55 PM   #25
That means absolutely nothing. The hagon springs will work better with an ohlins shock than with the hagon one for example.
Old 01-07-08, 09:36 AM   #26
Dangerous Dave
Large socket, can't remember the size but can measure later, 12mm socket for the yokes, breaker bar, a torque wrench, and a method of raising the front of the bike.
Yeap, just springs and oil.
Old 01-07-08, 11:13 AM   #27
gettin2dizzy
Spot on thanks!
Old 01-07-08, 11:38 AM   #28
Plus a 17mm for the axle, 8mm for the mudguard, 14 for the caliper bolts, 10 for the Pclips. (on the curvy)
Old 01-07-08, 11:44 AM   #29
Dangerous Dave
Duhh... forgot all about the front wheel and calipers, don't tell anyone I'm a mechanic/tuner in my spare time! Chris is spot on!
Old 02-07-08, 07:46 AM   #30
Spanner Man
Morning all.
I've fitted hundreds of Hagon springs over the years, & never had a complaint about them.They just work, simple as that!
One point worth mentioning when changing fork springs is that it's very important to follow the spring manufacturers recommendation for oil weight & level. Which, certainly in the case of Hagon springs can vary considerably form the standard settings.
I did supply a set of Hagon springs to a 1200 Bandit owner, who despite me telling him to use the Hagon oil supplied with the springs & to set the oil level to that written on the end of the box, proceeded to use a heavier oil set to nearer the standard level. Now they were the proverbial 'Iron bars'
It turned out that his 'armchair twiddler' mate from the pub said that a difference of 46mm in oil level must be cobblers, & that a heavier oil would be better in any case.... He knew better obviously, despite Hagon having spent several thousands of pounds on R & D.
When setting the oil level it's very important to make sure all the air inside the forks has been removed. so, pump the forks up & down at least a dozen times after adding the oil, & then with them fully compressed & vertical let them stand for at least 5 minutes before adding or removing oil to the correct level.
Cheers.
Spanner Man
Fork spring replacement... Forgot to measure travel beforehand. Troy SV Talk, Tuning & Tweaking 10 28-07-08 09:53 PM
Shock spring replacement... Gnome SV Talk, Tuning & Tweaking 5 30-06-07 05:55 PM
Fork Oil and Spring Overhaul Kit shelleyamy SV Talk, Tuning & Tweaking 14 27-06-07 07:48 PM
Fork Spring Upgrades Dicky Ticker The Essex Lounge 8 20-02-06 05:28 PM
Fork spring question.... Junior SV Talk, Tuning & Tweaking 4 07-01-05 09:20 AM
