Old 25-06-08, 09:43 PM   #21
esv650
Default Re: rasing the sv
Originally Posted by Dangerous Dave View Post
Get the weight off of the front forks and undo the clamps and lower the forks through the yokes again until the fork top is flush with the top yoke (the fork top, not the fork cap. See the pic below for example.).
Also note you should not drop the forks on the SV650 more than 10mm for the road and never lower the forks beyond standard without stiffer springs, this includes when lowering the entire bike!!!
Same goes for the rear really, get the weight off the shock and undo the bolts and swap over the linkage bars. You'll need a torque wrench by the way!
I would advise you return both front and rear to standard to begin with!
'SV650K4' - The bike has been lowered front and rear, i.e. longer linkage rods on the rear and the forks dropped through the yokes at the front.
thats exactly what i want to do. bring the bike to standard as when i bot it. the rear i can do. its the front am trying to figure out how to go about.
Old 25-06-08, 09:49 PM   #22
Dangerous Dave
The common ways,
1. Suspend the bike from a rafter using straps under the headstock.
2. Front paddock stand which raises the bike from under the steering stem.
3. Get a jack under the engine with the bike on its side stand and raise the front up by putting the bikes weight through the rear wheel and sidestand (make sense?)
Old 26-06-08, 02:52 AM   #23
esv650
much thanks to all the input.pics have really helped.after looking at my bike it all makes sense.i'll start the operation 2morrow as its supposed to rain the next couple of days.
we'll post results and pictures when its all said and done.
Old 26-06-08, 09:52 AM   #24
Dangerous Dave
No probs mate, good luck with it all.
Old 27-06-08, 11:14 AM   #25
esv650
Default Re: rasing the sv: UPDATE
ok. so i accomplished raising the rear of my sv. question is, do have to raise the front forks? bike rides good so far.i dont feel any handling issues.
Old 27-06-08, 11:20 AM   #26
sv650k4
have the forks been brought threw the yokes much or any???
Old 27-06-08, 11:35 AM   #27
esv650
not by much.
Old 27-06-08, 11:51 AM   #28
sv650k4
how much is not by much???
Old 27-06-08, 11:57 AM   #29
esv650
the bike was dropped 1.25 inches. am assuming same for the front.
Old 27-06-08, 12:10 PM   #30
sv650k4
i would measure the front 1st and see what it has been dropped.
