#21 |
i would be on the inside of the 3rd lane
#22 |
If anything, I wonder if you were too far out.
I aim to be quite close to the cars I'm passing, if only to ensure that I'm not in their blind spot and can be seen in their wing mirrors. It also helps, heaven forbid, that if they do pull out, the impact is minimal compared to being further out when you risk t-boning the car that pulled out rather than just scraping its side. Of course the further out you are, the higher the risk of affecting, or being affected by oncoming traffic. I speak from experience - this isn't good. There's no question that filtering in stationary traffic is the most dangerous - drivers rarely check their blindspots in this situation - and certainly not before their front wheels have turned and they've poked the nose of their vehicle out a bit. However, in flowing traffic, they're almost obliged to check mirrors and look over shoulders. Finally, if I'm filtering I'm always looking at the 3 or 4 cars that I'm about to pass ahead of me. The bottom line is that a finely tuned road-sense is what warns you of some chuffer about to do the dirty and close a gap that you were relying on - and that only comes with experience.
SV650 K3 - Gone. Now a member of the SV650.org Kawasaki brigade! |
#23 |
If Im filtering on a motorway due to an accident or a lane closure. I will rely on my fellow truck drivers as (whatever you believe) we do spend more time looking in our mirrors than drivers of cars. Truck drivers will normally stay in the lane they are in, the ones that don't are normally the recently qualified drivers. As a rule, the inside lane will always be moving faster than the others because we try to keep rolling, slower maybe but not stop start.
In town, I will take as much of the road as I can by slowly zigzagging to look bigger in a drivers mirror, sometimes this works, If not I just keep the revs up and slip the clutch a bit. A pair of Akropovics on a V Twin does the rest ![]() |
#24 | |
#25 | |
Once drove from Lands End to Northampton and met a 25mile traffic jam on the M5. Never stopped once. Learnt from the drive down that as soon as I came across a jam I get into the lane 1 and pootle along nicely behind a lorry. So much nicer than the start stopping you find in 2+3. |
#26 | |
#27 | |
If you appear in the wing mirror, then the driver is less likely to do a rapid pull out... and if they do, you've hit them at a relatively slower speed than you would have otherwise done - and your velocities will be in largely similar directions, than if you were further out. The oblique angle also gives you a greater visibility of what the front wheels are doing on the vehichles. I'm not preaching, I'm just saying that it's worked for me so far.
#28 | |
#29 | |
Trinity
I wouldn't consider the outside of 3 to be any more legal because either method is creating your own lane (that doesn't exist) Otherwise in the Thread, I pretty much agree with everything Muffles has said, as long as he advocates keeping away from junctions and other hazards on your right hand side. |
#30 |
Trinity
Just to add, if you are far enough out from cars you are overtaking IME you can either stop in the distance you can see to be clear, or if a car U turns in front of you in less than your stopping distance, you can accelerate and get in front of the car instead.
SVN vs SVS bar position. | SoulKiss | Bikes - Talk & Issues | 31 | 13-01-09 03:24 PM |
new position? | hovis | Idle Banter | 6 | 02-11-06 10:42 PM |
Anyone else in my position? | lukemillar | Bikes - Talk & Issues | 12 | 05-04-06 05:31 AM |
Position! | timwilky | Bikes - Talk & Issues | 21 | 02-05-05 10:51 AM |
Filtering position | wyrdness | Bikes - Talk & Issues | 5 | 26-08-04 03:39 PM |
