#21 | |
Java actually does support pointer arithmetic (as of Java 1.5). The only thing you can't do is uninitialise an object (though you can finalize() which is tantamount to the same thing really), and you can't deallocate memory. Last edited by Baph; 13-08-08 at 04:48 PM. Reason: spelling, again. :( |
#22 |
#23 |
Nah I posted again without meaning to (bloody annoying - not sure what I'm doing)
Basically at one point I wanted an Array of Arrays (for one type of graph), then changed my mind and went back to wanting a Hash of Arrays to produce separate graphs (by looping round the keys and using making a simple array of (2) arrays on each loop). I've done a ****e job of explaining it, not helped my mis-posting twice. I'll look at it tomorrow. Basically my problem is syntax and in there I'm not helped by not understanding things like references. |
#24 |
#25 |
queues are nice things to work with when you start to add functionality to insert into queues, delete from queue, service the first member, last member etc.
You end up with structures that contain pointers to the previous member, next member of the queue, plus either a pointer to the data item or if a privative type that data item. In that way, you can end up coding a whole structure to implement stacks (simple push/pop) for a LIFO implementation. or your FIFO. You then need to build a good enumerator round it to efficiently walk the queue. Mike, I think of a queue (from above), as more than a FIFO as there is a lot more you can do with it. my best analogy of a FIFO is in a pipe implementation, there is only two methods involved to insert something to the tail end of a pipe and extract something from the head end of the pipe. Baph Thanks for the heads up re pointer functionality of 1.5. I must admit I have not read the spec, and tend to still think 1.2/1.3 with some added extra class implementations
Not Grumpy, opinionated. |
Friends, Who'd have 'em? | Stu | Idle Banter | 22 | 10-12-08 11:12 PM |
Who'd have thought? | licoricepizza | Idle Banter | 0 | 22-11-07 03:51 PM |
Who'd be up for.......? | independentphoto | SV Ecosse | 51 | 02-09-07 07:52 AM |
Who'd be in sales! | Mogs | Idle Banter | 3 | 12-02-07 04:01 PM |
Who'd like one of these.. | kciN | Idle Banter | 7 | 02-08-06 08:52 PM |
