#21 |
I have a K8 Sport myself I have been told my Suzuki dealer the bike will run really poor if you put a full system on the bike.
The ECU is set up for the oxygen sensor in the standard exhaust, If you remove the oxygen sensor if will affect the FI fuel injection system. Also the FI warning light will come up on the clocks all the time and you will have to get round the problem of removing the fuse from the fuse box for oxygen sensor. |
#22 | |||
The Sick Man
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
#23 |
Evening all,
I have good news. I called garage yesterday to say, "ok let's go back to stock" but luckily the guy who's working on it wasn't in. Today he called me and said that the new sensor has a slightly different thread, i'm not sure on the details but basically it can be mounted easier, and they managed to get it to fit ok in the right place. So I get tokeep the exhaust, and have the lambda where it should be! I'm rather pleased. Ragarding running after getting a new system, I presume it might be a good idea to get it dyno'd... can anything be done to alter these without going power commander type new ecu route? Or will the ecu work it all out itself? |
#24 |
Glad it is all sorted Griffo, what exactly did they do to overcome the issue?
The standard ECU can be remapped, this is the way to go with your full system. A PC is an option but it is a lot more expensive and the whole unit is very OTT for a SV650. The SV's with the oxygen sensors can compensate for slip-on exhaust, not full systems as the set up isn't that intelligent. Last edited by Dangerous Dave; 05-09-08 at 07:38 AM. |
#25 |
Thanks Dave, I'll probably take it to JHS then and get that sorted before too long. What sort of symptoms should I expect, it not being remapped?
Regarding what exactly they did, I will find out for you when I pick it up, which may be tomorrow if my brother is excellent. I'm more excited than all those world-ending things that are going to pop out of the LHC! |
#26 | |
Originally, the garage wanted to wire in a resistor, but didn't know the value of the resistor to use due to changes made to the K8. KISS theory: Keep it simple stupid. Use a potentiometer & just wind it up to the value that works (ie, stops the FI warning light coming on). Get out a DMM, and you know the resistance offered by the potentiometer if you want a more permanent solution. However, that won't make the ECU vary fuel/oxygen mix dependant on exhaust gas, as you're using a resistor, not a sensor. |
#27 |
Well I got the bike back, and it's running lovely. Seems a lot smoother than before, sounds rather nicer too. All the chap said was they managed to mount the sensor as the thread is in a different position to the k7. I apologise but in my excitement I didn't ask much else
![]() I'll take a photo or two next time I take her out for illustrative purposes. |
#28 | |
Jambo
#29 |
Late to this thread too, but I was going to add that the exhaust is clearly not a K8 version as confirmed by Akro and those supplying and fitting the exhaust (if one of the same) should give you full warranty for their suply and install.....I hope this is the case. Good Luck with it, I am not jealous at all!
Akrapovic full system query? | Brettus | SV Talk, Tuning & Tweaking | 6 | 12-10-08 01:45 PM |
Speed sensor rotor issue - images | dclifford | SV Talk, Tuning & Tweaking | 19 | 29-09-07 06:38 PM |
Akrapovic | phil24_7 | Exhausts | 0 | 10-02-07 12:05 AM |
Akrapovic | noisie | For Sale - SV's and SV related items | 15 | 12-09-06 03:37 PM |
SV650SK2 speedo sensor resistance query | mlavender | SV Talk, Tuning & Tweaking | 0 | 14-06-05 08:10 PM |
