Old 04-09-08, 07:56 PM   #21
zadar
Default Re: Ignition advancer wanted
yes
Old 05-09-08, 10:52 AM   #22
embee
embee's Avatar
Do double check you slot it in the correct direction, it's a sort of double mirror image effect! You'll be disappointed if you go the wrong way.
The crank turns in the same direction as the wheels (pretty failsafe description ), so to advance the ignition you want to move the pick-up so it is in a position equivalent to where the crank is turned backwards from its original position, i.e. the spark will be triggered earlier in the rotation.
Old 05-09-08, 11:58 AM   #23
boo86
Got it. It sounds like this weekends mission.
ignition advancer svryanpompy SV Talk, Tuning & Tweaking 3 18-03-07 12:15 AM
ignition advancer svryanpompy SV Talk, Tuning & Tweaking 22 08-03-07 03:46 PM
ignition advancer svryanpompy SV Talk, Tuning & Tweaking 6 07-03-07 10:59 PM
Ignition advancer? sixstring SV Talk, Tuning & Tweaking 19 22-07-06 06:39 PM
Ignition advancer?????? bobbydee SV Talk, Tuning & Tweaking 10 16-03-05 06:04 PM
