Old 10-09-08, 06:46 PM   #21
Sean_C
Default Re: Books.
2 stroke and 4 stroke:
The engines are called the above because of the amount of “strokes” the piston makes per cycle, a stroke being the upwards or downwards movement of the piston.
The strokes are intake, compression, combustion and exhaust, each achieved in the following way for a 4 stroke:
Intake- The valve opens allowing in a mixture of fuel and air as the piston travels down the cylinder.
Compression- The piston travels back up the cylinder, and compresses the mixture. The valve is closed.
Combustion- The compressed mixture is ignited by the spark plug. The explosion sends the piston back down the cylinder.
Exhuast- The valve is opened and the piston goes back up the cylinder. The gases are pushed out and the whole process can start again.
2 stroke:
Stroke 1: The piston travels up the barrel, opening the inlet and sucking fuel/air into the engine, precisely the crankcase. At the same time, the fuel/air mix at the top of the engine is compressed.
Stroke 2: The compressed mix is ignited, sending the piston back down the barrel, exposing the exhaust port and the transfer port. This sucks the fresh mix up to the cylinder and displaces the gases.
I now understand why a 2 stroke makes twice as much power compared to a 4 stroke- the 2 stroke ignites once every revolution, whereas the 4 stroke ignites every other revolution.
Thanks tim
Old 10-09-08, 06:47 PM   #22
Sean_C
Default Re: Books.
And to both Tims, please teach me all you will
Old 10-09-08, 06:51 PM   #23
timwilky
timwilky's Avatar
Default Re: Books.
Ok, based on what you now know. A 4 stroke has valves to control inlet/outlet and a 2 stroke uses ports. how are a 4 strokes valves opened, What simple mechanism controls all the timings of what to open when
Not Grumpy, opinionated.
Old 10-09-08, 06:56 PM   #24
Sean_C
Default Re: Books.
A 4 strokes valves are opened and closed by a cam shaft, which I believe rotates at half the speed of the crankshaft. I'd imagine that when and how much the valve opens is dictated by the shape of the cam itself.
Old 10-09-08, 08:56 PM   #25
Tim in Belgium
Default Re: Books.
What is meant by a high lift camshaft?
And what is meant by a long duration camshaft (i.e 290 deg)?
Old 10-09-08, 09:24 PM   #26
Sean_C
Default Re: Books.
High lift camshaft- more air and fuel into the engine. Better air flow.
Long duration- how long the valve is held open for?
Old 10-09-08, 09:39 PM   #27
Sean_C
Default Re: Books.
After some more reading..
Long duration cams are conducive to making better high end power, whereas shorter duration cams are better for making low spped torque and throttle response.
Please note I'm not just reading this and posting this, I'm learning and remembering it too
Old 10-09-08, 10:26 PM   #28
Default Re: Books.
OK then, get a bit more involved about cam duration.
Why?
Old 11-09-08, 09:31 AM   #29
Sean_C
Default Re: Books.
At work so I can't do much. Why? Err.. Why have different durations? So you can controll the duration the valves are open, how far they're open. Going from standard cams to race cams.. Do it for a performance increase- it'd make more power, probably more power higher up the rev range.
I can't research until I get home
Old 11-09-08, 09:42 AM   #30
Sean_C
Default Re: Books.
Oh, also, you can get the opening and closing of the valves (inlet and exhaust) to overlap.
Motorcycle books! sam anon Bikes - Talk & Issues 8 21-08-08 12:43 PM
Dan Brown Books gettin2dizzy Idle Banter 15 24-10-07 01:29 PM
Buying books Blue_SV650S Bikes - Talk & Issues 6 16-10-07 05:58 PM
Now that's a turn up for the books Baph Idle Banter 8 08-06-07 11:39 AM
favourite biking books? doc100 Idle Banter 0 09-01-70 12:09 PM
