Old 22-09-08, 11:56 AM   #21
Dangerous Dave
Default Re: How to remove Headrace bearings?
Originally Posted by Geoffrey View Post
We have the whole front end almost, just looking for clip-ons and calipers (although DD is digging around in his sheds for some).
I have a set that will fit, they are six pots off of my TL but I still think four pots are much better. You can borrow these whilst you source some four pots if you want?
Old 07-10-08, 06:32 PM   #22
Geoffrey
I have some TL clipons now, I think that is it now correct?
Old 08-10-08, 12:31 AM   #23
Yes for 750SRAD forks, and also probably the later USD forks too, but not sure about later uns
Old 08-10-08, 06:48 AM   #24
Dangerous Dave
Yeap, you have everything now. Let me know when and i'll send the stand up....
Old 08-10-08, 05:18 PM   #25
Red Herring
Red Herring's Avatar
For supporting the bike I use an old metal builders trestle, you know the sort that extend up and down. You pull it apart, slide the bottom half under the bike so it sits just behind the headstock (the bottom crossmember is just in front of the front cylinder) then put the top half back on and use two straps between the top crossmember and the bike frame to support it. Guaranteed not to fall over.....
bearings sv_rory SV Talk, Tuning & Tweaking 5 12-02-09 07:29 PM
Gsxr Bearings carsounds_dan SV Talk, Tuning & Tweaking 3 04-07-08 11:58 AM
wheel bearings mart SV Talk, Tuning & Tweaking 1 21-05-06 05:14 PM
Suspension bearings??? svrash SV Talk, Tuning & Tweaking 13 23-04-06 07:19 PM
How D'you remove wheel bearings... Stormspiel SV Talk, Tuning & Tweaking 9 22-11-05 09:21 PM
