Old 25-09-08, 02:39 PM   #21
AndyBrad
Default Re: Front brake res help! Please!
A list wouldn't have helped you not butcher the screw. An impact driver or the correct size screwdriver would have, especially as you never got the old one out anyway. Stainless will still corrode to a degree, so use a little blob of copperslip or grease on the threads before putting the bolts/screw back in.
TO BE FAIR
i used the correct size driver. I also didnt butcher the screw. It was corroded and thats why it failed. An impact driver would have had no effect and you carnt get copperslip into a corroded screw thus if we have a list of sizes then we could replace them as and when hopefully preventing future problems?
Old 13-11-08, 06:08 PM   #22
AndyBrad
blooy hell gone and done the same trick with the rear one now. Bloody great this stuff they make the bolts out of. I got a screw extractor this time and its kust turned a big hole in whats left.
Grrrr
Old 13-11-08, 06:12 PM   #23
I might have a spare rear res.
Old 13-11-08, 06:17 PM   #24
AndyBrad
hmm how much would sir want for such an item? Not completly cut it off yet so m going to try again in a bit when it stops raining.
you know those 2 side bits that go down from under the rear seat. well where do they come out? and lets say for example somone dropped a few driver bits don there will they jus rattle about till i get to them or would they drop onto the road?
Old 13-11-08, 06:20 PM   #25
I take it you already have the rear plastics off?
Old 13-11-08, 06:23 PM   #26
AndyBrad
urm noooooo should i?
Old 13-11-08, 06:23 PM   #27
AndyBrad
btw im on about that bit where the tank stand would go
Old 13-11-08, 06:25 PM   #28
Yeah. Either be able to get down the side with the plastic off, or they'll just be hanging around in there. No wonder you rounded screws out you can't get even grip on them with plastic still on.
Old 13-11-08, 06:31 PM   #29
AndyBrad
hmm tbh the driver did locate quite well as the res kind of flexes out a little. It just turned the metal out of the screw. Otherone was fine although it did need a little persuasion. Ill leave it for another day i think and take the plastics off as you suggest.
Old 13-11-08, 06:32 PM   #30
Obviously not that well
WTD - rear brake lever, front brake lever, r & G crash bung, nik_nunez Stuff Wanted 0 17-10-08 08:27 PM
Front Brake - Rear Brake? Stradders Bikes - Talk & Issues 35 17-09-08 04:44 PM
K3 front brake lever, Front indicator (RH), Front Mirror(RH), Bar End (RH) leegriffiths128 Stuff Wanted 0 23-07-08 09:11 PM
Front brake not activating brake light properly SVeeedy Gonzales SV Talk, Tuning & Tweaking 5 27-02-07 12:09 PM
brake light flickers when the front brake pulled in - K4 dclifford SV Talk, Tuning & Tweaking 9 05-09-05 10:39 AM
