Old 09-10-08, 08:33 AM   #21
Dangerous Dave
Default Re: Winter use! Rust?
Originally Posted by Miles View Post
I thought it was a pain to get off
It is, in a way. If you use the Scottoiler product that will simply come off with water (hence why it isn't any good when it rains), with ACF-50 you will need a detergent of some kind and a lot of elbow grease to remove most of it.
Another plus for ACF-50 is that it does leave a small protective layer behind, especially on the parts that bake it in.
Old 09-10-08, 09:26 AM   #22
silent11
so if i buy this acf stuff and apply it etc
it means in order for it to stay on i cant wash the bike at all?
unless i replay everything again?
thanks
phil
Old 09-10-08, 09:58 AM   #23
neio79
I have used ACF-50 on my Kwak, all year round from having it new. It was ran in last winter through December and January so got a good coating of road gunk.
I re apply ACF-50 every time I wash the bike which is quite often. So I am sure as it leaves a bit behind even with washing all my bike has a good build up of ACF-50 all over. There is not one bit of corrosion on my bike, not one furry bolt or off colour piece of metal. The best way to apply ACF 50 is to set aside a couple of hours and go around every bolt, and bit of exposed metal with a paint brush. I even apply it to the brake lines and callipers’, taking care to ensure none goes on the pads or discs. Where I can’t get to with a paint brush I spray it with GT85. I done mine this weekend just gone, and even removed the fairings to ensure I covered everywhere.
Every time I was the bike it comes up as though its just rolled off the production line. That said its not a Suzuki, so I am not onto a losing battle to start with.
Old 09-10-08, 10:38 AM   #24
Dr T
Thanks for this guys.
I have ordered ACF50 and was going to spend ages cleaning the bike before putting it away for winter. So I'll make sure I cover everything and keep a close eye on it.
I'm used to the rust being a fan of Italian motors, but never thought my Suzuki would be tarnished with the same brush. Hopefully since it's a K8 I'll be able to keep the rust at bay.
Old 09-10-08, 11:13 AM   #25
Dappa D
with ref to acf-50....
i used to have a clr125 "cityfly" that had chrome/silver wheels....used to put vaseline on the wheels after washing to protect as i knew i wouldnt have it long so anted to keep it nice for when i sold it....
so acf-50 alright to use on the wheels? apply with a rag? then leave till after winter??
Old 09-10-08, 11:16 AM   #26
neio79
yes 100% i have done that on my little CG. so far so good. havent bothered on the kwak as the wheels are painted anyway.
Old 09-10-08, 11:38 AM   #27
Dangerous Dave
No, with ACF-50 you will need a detergent of some kind and a lot of elbow grease to remove most of it.
Yes, yes, and yes.
Old 09-10-08, 11:40 AM   #28
Dappa D
many thanks.....
Old 24-10-08, 02:51 PM   #29
Nobbylad
Nobbylad's Avatar
Worth the extra £20 to be a lazy ar$e, or am I better off spending a couple of hours cleaning my bike, stripping off the plastics and doing it meself?
http://www.brmc.co.uk/acf-50.htm
Old 24-10-08, 02:53 PM   #30
Innaccessible places all get coated anyway when it gets vaporised off the engine and pipes. Save your dosh and do it normally.
Rust. ooger Bikes - Talk & Issues 29 13-10-07 08:04 AM
Rust! -Ralph- SV Ecosse 17 01-03-07 04:54 PM
Rust? Jdubya Idle Banter 1 06-07-06 08:29 PM
What can I do about this rust ? SpankyHam SV Talk, Tuning & Tweaking 12 08-06-05 04:29 PM
rust!!!!!! H-Gerickemark SV Talk, Tuning & Tweaking 7 13-12-04 11:35 PM
