View Poll Results: Which shock should I go with
You've got a k5 gsxr thou shock, it won't be perfect but will be good enough 7 36.84%
You're quite heavy so you'll feel the benefit by fitting a stiffer (kwak) shock... 1 5.26%
Whatever yorkie chris suggests is the best choice... 11 57.89%
Voters: 19. You may not vote on this poll
Old 21-10-08, 12:10 PM   #21
Default Re: the shocking truth about shock absorbers... (noob questions as asked by myself)
you've already bought it too... so might as well fit it and see what it does
Old 21-10-08, 12:19 PM   #22
Paul the 6th
Paul the 6th's Avatar
lol... just thought I'd try and save d1cking around having to fit and remove, then refit a different shock... just emailing demon tweeks about some fork springs...
" Hi Paul,
Ohlins fork springs for your SV are £74.00, or Hyperpro do a progressive kit for £105.00.
Regards"
seems a bit expensive for progressives? Most people seem to say they paid around 70-80 quid for similar stuff? Trying to rack my brains and search through previous threads for other manfacturers. Am I right in thinking there's a company called Maxton? and do hagon do them or is it only shock absorbers?
googling like mad since I've got no work to do until 3pm...
Old 21-10-08, 12:20 PM   #23
ThEGr33k
Gixxer shock should be fine mate.
I use Penske...
Since I put mine on WOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOW.
Old 21-10-08, 12:22 PM   #24
Paul the 6th
I use Penske...
didn't it take them about 3 years to get it to you or was that someone else?
yes.
Old 21-10-08, 12:27 PM   #25
100 quid is taking the pi$$.
Nick you're a brand wh0re
Old 21-10-08, 12:30 PM   #26
Paul the 6th
yeah 100 quid is a lot of money. Gonna ring hagon and maxton and see what they say. Looking for about 80 quid tops, bit of bargaining is in order
Old 21-10-08, 12:33 PM   #27
ThEGr33k
yes.
Yes... But thats because they were **** tards. Once they actually ordered it from Yank land it arrived in 2 weeks. Did cost a fair wack though
I know.
I put that on along with RSV linkage and its raised the rear a little (on minimum on shocks height adjustment, might add a few mm ) and its made turn in ACE get on the power way early and it just gets on with it!!!
With RSV linkage and the spring to suit me the springs gone from 800lb to 500lb! Only thing is that I now know that my forks need some softer springs (got 1.05kgmm in there atm They are ment for people weighing twice me!!!).
Anyway sorry for going off subject. Fit the Gixxer shock see what you think, if its wrong height they if its height adjustable then raise it if not play with dog bones. If the spring rate is wrong see about getting a stiffer/softer spring in there.
Old 21-10-08, 12:44 PM   #28
Paul the 6th
I'm scared nick. Is everything going to be ok?
Old 21-10-08, 12:47 PM   #29
Hagon progs springs are about 60-65 paul. I prefer em to the ohlins on the other SV
Old 21-10-08, 12:51 PM   #30
ThEGr33k
It'll be fine!
I think...
Many noob questions need answering? AndyL Bikes - Talk & Issues 29 08-08-08 06:27 PM
Noob with stupid questions MeatSwinger SV Talk, Tuning & Tweaking 1 03-02-08 11:47 AM
Ohlins shock questions? svrash Bikes - Talk & Issues 21 17-10-06 09:54 AM
Questions asked over terror raid...... akbarhussain Idle Banter 161 13-06-06 07:31 PM
Noob Questions jeremysilver75 SV Talk, Tuning & Tweaking 11 01-06-05 03:45 PM
