Old 22-10-08, 09:57 PM   #21
Frank
Default Re: I have been raped
Wish I could grow a beard..............
Old 22-10-08, 10:11 PM   #22
i found a solution to 'razor burn/sensitivity'
after shaving i wash my face with ........................................
head and shoulders shampoo... works a treat
Old 22-10-08, 10:12 PM   #23
oooops .. sticky return button .. sozzz peeeeps
Old 22-10-08, 10:14 PM   #24
Spokey
Have you not heard of Ebay ....
I also suffer - I find I can only use the old gillette twin bladed sensor with shaving oil - I buy loads at a time - still using ones I bought about 4 years ago !
Like these - ok, so they are the womens ones, but exactly the same as the mens only white plastic instead of grey
http://cgi.ebay.co.uk/100-X-GILLETTE...d=p3286.c0.m14
nana
Old 22-10-08, 10:18 PM   #25
i was also told 'by a beautician yearssssss ago' never to use aftershave directly after shaving. and if you do try to use a spray type....
Old 23-10-08, 06:40 AM   #26
Jdubya
Shaving routine should be as follows (I worked for a company that specialised in mens grooming while at school):
*metrosexual mode on*
Wash face in warm water - It opens the pores, then apply shaving foam or combination of shaving foam and shaving oil. Also, if applied using a brush, it helps to stimulate the nerve endings on the skin. Shave as normal and always shave with the grain as going against the grain causes ingrown hairs and can be very painful. Use a sharp blade so replace regularly. Rinse face with warm water to clear any reamining foam/oil. Then, and this is crucial, rinse you face with cold water. This closes the pores and reduces sensitivity. Dry with a clean towel and do not apply after shave directly to the skin. If you do have sensitive skin then use either an unfragranced moisturiser and once dried, then apply the after shave or use an aftershave balm...most good fragrance houses will make an aftershave balm.
Anyway, HTH.
*metrosexual mode off*
Old 23-10-08, 07:05 AM   #27
Baph
I find if I just run the hair clippers over my chin every 3 weeks or so it doesn't hurt at all.
The clippers were 19.99, in 1999. Bargain.
+1.
Though I have a wet shave for important things, if I can be bothered.
Old 23-10-08, 07:11 AM   #28
steveg
steveg's Avatar
Just grow a beard , its helps to keep your neck warm this weather
Cheers Steveg
ex - red sv650s 06 reg
Now Triumph sprint 1050 ABS 05 Reg
AKA Papa Smurf
steveg is offline   Reply With Quote
Old 23-10-08, 07:43 AM   #29
carty
Bunch of girls!
Old 23-10-08, 08:03 AM   #30
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
Originally Posted by Daimo View Post
For the sum of £14.98 for 8, yes EIGHT fecking blades for my razor.
I have sensitive skin on my face, cheap razors just do not work and are painfull. There are only a few razors that seem to stop this irritation for me....
serves you right for being a poof mate
here's what i use:
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
