#21 |
#22 |
#23 | |
![]() They also mentioned that they had worked on a system that used a reletivly much lower temp to do the same job. If this is right then it will be much easier im sure. |
#24 |
Is going to need a massive energy input too though, not just temperature, heat.
Roughly 45MJ/kg at total efficiency. Roughly 300W/m2 from sunlight in a really really hot desert, some sums give that as roughly 41 hours to produce 1kg of petrol from 1m2 of ground.
#25 |
Doing it at a lower temperature will be easier, as you can use lower quality heat to do same job, but still needs the massive amount of heat transfer.
#26 | |
Oh yes i think the mirrors they used were large... about maybe 4-6M diameter, not sure as it didnt really show very well. Luckily for this there is no limit of desert really. A good use for it is this ![]() |
#27 |
OK so lets fudge it a bit. Say it was 48 hours per kg ... so .5kg/daym2
A random statistic gives up petrol consumption as 72 million liters a day. So at 0.369l/day-m2. That's 195 million square meters of mirror. Just for the UK's fuel use. Lotta desert that. Edit: 72 million liters is 5.3x10^7kg. 2.34x10^15J of energy a day, equivalent to 2.7x10^10W. That's nearly 7 chernobyls worth of power output. Just for petrol.
Now rebuilding a 63' fishing trawler as a dive boat Last edited by yorkie_chris; 26-10-08 at 04:53 PM. |
#28 |
Aye... but they said something about 4-5Gallons (US) which is more like 8-9KG's over 24 hours... So maybe they do require considerably less power than you think?
#29 |
6m dia. mirror is 28m2. 15 kilos of fuel a day roughly by my guesstimates. 19.3 liters ish. 4 gallons ish.
If anything that confirms my bodge-maths. Edit: Bugger... misread the post ... but yes would make more sense. Just take that to mean they're getting 60% efficiency at a guess...
Now rebuilding a 63' fishing trawler as a dive boat Last edited by yorkie_chris; 26-10-08 at 05:35 PM. |
Like old vehicles? you'll love these. | rictus01 | Photos | 8 | 08-05-09 09:28 PM |
Cover on other vehicles | rubberduckofdeath | Idle Banter | 4 | 20-12-07 09:24 AM |
Vehicles with lights out: | MrMessy | Idle Banter | 8 | 04-09-06 04:38 PM |
Other vehicles move over for me.... | rob13 | Bikes - Talk & Issues | 19 | 03-04-06 03:33 PM |
