View Poll Results: Which uses more fuel?
Engine braking 7 41.18%
clutch in and use brakes 10 58.82%
Voters: 17. You may not vote on this poll
Old 17-11-08, 02:16 PM   #21
SoulKiss
SoulKiss's Avatar
Default Re: Which uses less fuel?
Originally Posted by startrek.steve View Post
Whats a sid squid?
This is a Sid Squid
Old 17-11-08, 02:24 PM   #22
Daimo
Originally Posted by breakz187 View Post
I thought that the engine braking causes the vacumn to build up massively, reducing the amount of pressure within the fuel pressure regulator. I thought this was how it worked on injected petrol engines anyway. Obviously the injectors will have different control logic but i dunno...
Think thats a fair bit old on the early injection engines.
Things have come ona long way since then.
But on a modern engine, rolling + in gear uses no fuel, but taking it out of gear and idling uses quite a bit of fuel.
Old 17-11-08, 09:14 PM   #23
Jdawg
Tend to agree with Jambo, modern Fuel Injection systems will not inject any fuel into the combustion chamber when at 0% throttle, however in older FI engines this may not be the case. Anything with a carb will use fuel on 0% throttle.
Old 17-11-08, 09:27 PM   #24
Originally Posted by jambo View Post
Depends on the fuelling system. Top Gear took a V8 diesel Audi to Edinburgh and back on a tank of fuel a couple of years back. With the modern FI in that if you coasted with your foot off the gas the FI put no fuel into the engine at all, as the engine braking was keeping it turning. A similar system was much criticised on Yamaha's FZ1 when it came out as it led to a hesitation as you went from negative to positive throttle while cornering.
Carbs, of course will always add a little fuel as long as the engine is turning, but using smooth, gentle throttle in the correct gear and not building up speed that you then need to scrub off helps fuel economy.
He's right. As for the later comment about the Yamaha, all FI systems go 'dry' on high vacuum/shut throttle.
If all else fails, fit a Sid Squid, annoyingly this makes more difference to fuel economy than anything else I've tried.
There's no substitute for being fiscally sensitive, .
Old 17-11-08, 09:44 PM   #25
Spikenipple
Spikenipple's Avatar
Are you sure no fuel is injected (FI bike obviously) when the clutch is out and you're engine braking?
That would effectively be the same as flicking the kill switch, which is completely different than just using engine braking (on my bike anyway, it slows you down a lot faster). I was under the impression that it will inject just the amount of fuel it needs to stay at idle speed.
Had: K7 SV650S in Candy Sonoma Red
Now: MT-09
My old SV
South & West Surfer
Spikenipple is offline   Reply With Quote
Old 17-11-08, 10:27 PM   #26
metalmonkey
So whats the going price in today's climate for Sid Sqid after maket mod? What does the bidding start at?
Old 17-11-08, 11:00 PM   #27
arcdef
i read somewhere that with carbed engines it makes a difference to the fuel usage when coasting but with the electronic injected engines they use more fuel when coasting than if you stay in gear as the injectors shut down or something btu i may be talkign out of my bum.....
Fuel @ the NEC Bassman SV Talk, Tuning & Tweaking 4 19-11-07 12:24 PM
Not Fuel, so who else is there? Berlin Exhausts 7 05-09-07 04:11 PM
Replacement fuel light / fuel tap riktherider SV Talk, Tuning & Tweaking 7 14-05-07 06:41 PM
Dry fuel BURNER SV Talk, Tuning & Tweaking 8 18-11-05 05:09 PM
Fuel cap? Bikerz SV Talk, Tuning & Tweaking 3 06-06-05 08:46 PM
