#21 |
#22 |
The Teacer
I've only skimmed through the rest of the thread but I don't think anyone's mentioned thyroid problems yet. Over active, under active or being attacked by ones own immune system can have strong psychological as well as physical effects.
When it happened to me there were definate indicators of memory loss, a bit of confusion and depression. Weight changes can also be an issue, either gaining or losing or not being able to shift any. Other possible sypmtoms include erratic sleeping patterns, inability to control temperature (eg staying freezing cold or sweaty hot even though the room temp is OK) dry skin, poor hair. If you put your fingers softly on your adams apple you may be able to feel swellings either side when you swallow Go to your GP and insist on a thyroid function test - some are more ready to do it than others. If there is a problem though, it's easily fixed. Don't worry. I've had it for 15 years Mind you I could be completely wrong and you've got fed upness with a touch of tiredness plus a dose of lack of sunshine blues ![]()
There's a fine line between a hobby and a mental illness |
#23 |
Well I had my thyroid checked last year, but I'll be sure to get it checked again, but I know all about it as Jax has a thyroid problem.
#24 | |
As for losing your memory; as you've drawn attention to it, you notice it more and consequently think it's getting worse. Sounds just like winter blues and fatigue to me. It's not normal to feel happy as Larry all of the time. I'd avoid getting any meds if you can, as they can be an **** to get back off. |
#25 |
In my case was checked for everything, as all my symptoms mirrored those of thyroid and diabetes, as I was also having the feeling of passing out at work, and had got to the stage where I could sleep 24 hrs a day and it wouldn't stop me feeeling tired, but neither tests found anything. A lot of symptoms of depression and anxiety mirror those physical problems.
I for one wouldn't agree that I needed anti depressants, I certainly don't agree with taking them, i held together for so long without them..why me and why now? But after doing the silly thing of falling off the bike, which was partly road and weather conditions, and partially my fault, because I couldnt even do that properly at the time...I knew I had to address the issue. Firstly they put me on Fluoxetine..which made me so ill, I couldnt even get off the sofa for the world spinning( I think I took two of them and that was enough) then they put me on Citalopram, which turned me into a drooling zombie, then they put me on an 'old fashioned' one Lofepramine ..slowly the marbles that I did have, I have started finding under the sofa! They also gave me the option on CBT, and councelling which i start tomorrow. Still don't agree with the taking the drugs, but if they help me get out of the pit I've falllen into, then so be it.I've even got to the stage where I can see a point where I can start coming off them........oh and slowly my memory is coming back ![]() ![]() Those at work have been particulary supportive.The day i went back after 2 months off, they asked me how I was etc, I just replied ''well you knew i was nuts in the first place, but now I am officially a nutter!'' they all laughd and said at least i hadnt lost my sense of humour, and that was that, settled in slowly and they've all gathered round...and not because they feel sorry for me or anything, its because we are a close team ![]()
Suzy, yellow 2001 SVS. Kitty, V-Raptor 1000, ZZR1400<<its my bike now Pegasus! Hovis 13.8.75-3.10.09 Reeder 20.7.88-21.3.12 Last edited by dizzyblonde; 08-12-08 at 04:58 PM. |
#26 |
I've had the same with thyroid, and the best thing for it if you don't want medication is, BRAZIL NUT'S, unless your alergic to them!
Nuts are also good for your memory, I eats loads around the time of exams, and I must admit they do help. I can't remember (ha ha) where I read about this, but certainly works, and ideal if you don't want to take medication. Oh yes, and as a sufferer of depression, the other food that helps is turkey, once I found this out I've made sure I've eaten turkey every week, and touch wood, I've been fine for a couple of years now and not needed to go back on the medication. HTH Grinch. Lou |
#27 | |
#28 |
oops sorry... all of the above could also be symptoms of Xmas
#29 |
ooh I know! I know!
See a doctor. |
#30 |
![]() Really ![]() ![]()
Suzy, yellow 2001 SVS. Kitty, V-Raptor 1000, ZZR1400<<its my bike now Pegasus! Hovis 13.8.75-3.10.09 Reeder 20.7.88-21.3.12 |
Anyone need any memory? | Caddy2000 | Idle Banter | 10 | 27-02-09 02:38 PM |
In memory of ASM-Forever | Stig | Thames Valley | 48 | 06-11-08 06:50 PM |
Lack of motivation.. | chasey | Idle Banter | 10 | 04-06-08 02:33 PM |
Motivation - HELP!!! | krhall | Idle Banter | 17 | 11-03-08 12:09 PM |
in memory of... | embee | Bikes - Talk & Issues | 15 | 29-03-07 09:53 AM |
