Old 10-12-08, 10:18 PM   #21
noob-saibot
Default Re: Check your oil level!!!
Originally Posted by arcdef View Post
whats the cause of this clutch cover leak? just a gasket??
Over torquing at the factory i think..
Old 10-12-08, 10:53 PM   #22
Stu
Trinity
Stu's Avatar
aye still don't change from the fact ive got no coolant! saying that its been so cold recently i hope it hasn't hurt it
Having no fluid in the expansionbottle says nothing about how much fluid is in your radiator. you might be lucky and te radiator etc. is fine
Old 10-12-08, 10:56 PM   #23
arcdef
hope so!!! need to fill up with some coolant though, what spec is it meant to have and can i get it from any motorfactors??
Old 11-12-08, 11:55 AM   #24
Dangerous Dave
Over torquing the clutch cover bolts will cause the cover to warp slightly, this will ruin the seal the o-ring gasket is trying to make.
Old 11-12-08, 01:10 PM   #25
AndyBrad
oh bugger. that may be why mines dripping then. Thourght i had fixed it by nipping it up.
Old 11-12-08, 01:28 PM   #26
Dangerous Dave
Clean it all up with degreaser and go for a ride, you will see exactly where the leak is coming from then. Usually silicone sealant is enough to stop the leak.
Brake Fluid Resevoir Diaphragm and level check branny SV Talk, Tuning & Tweaking 11 27-01-09 04:11 PM
How to check fuel level? flymo Mini-Twins 1 29-01-08 05:05 PM
anyone wanna swap my hi level leo vine for a low level one spakmitten Exhausts 1 16-06-06 08:59 AM
anyone wanna swap my HI level leo vince for a low level one spakmitten SV Talk, Tuning & Tweaking 1 16-06-06 05:25 AM
Coolant level check... how? ujoni08 SV Talk, Tuning & Tweaking 6 29-06-05 08:39 PM
