#21 |
#22 |
If i remember correctly i think it was clockwise to tighten.. you should notice pretty quickly by the movement along the markings
oh and as Glade mentioned careful with the adjuster makers bending and scratching the swingarm when loosening the nut.....................yep that's right....... I did exactly that scratched mine earlier this evening ![]() |
#23 |
i always thought it was clockwise to tighten and anti clockwise to loosen for all threads except tow hitches (because the thread of the rope being used to toe will turn & loosen the bolt if it was a normal thread) and various other important components which usually rotate (and said rotation would undo the screw/bolt/fixing)?
RIP Reeder 20/07/1988 - 21/03/2012 - You were awesome Cbf600, sv650, sv1000, gsxr 750 srad, KTM adventure 950, gsxr 750 k1, gsxr 750 srad, fazer 1000, zx9r ninja.. |
#24 |
quite possably. Although i never got around to tightening the chain and it had about 32-34mm of free play so having the chain too slack may well have caused it to break. Although tbh im not sure.
now heres the think ive just checked the service record and that chain has done 1378 miles total!!!!!!!!!!!!!!! i only had problms when i switched to that wurth lube that appears to be like water. |
#25 |
Just for argument sake, if you think your markers are out of alignment what is the best way to check the wheel alignment?
#26 |
#27 |
#28 |
#29 |
#30 |
em good old fashioned way to parrelel straight strips of tape on the ground the width of the tyre
Chain adjustment. | Gary C | SV Talk, Tuning & Tweaking | 6 | 08-06-08 06:20 PM |
Chain Adjustment | plowsie | Bikes - Talk & Issues | 14 | 22-04-08 10:26 AM |
chain adjustment | wanted sv650 | SV Talk, Tuning & Tweaking | 8 | 11-05-06 01:01 PM |
Chain adjustment?? | GC-SV | SV Talk, Tuning & Tweaking | 4 | 07-04-06 12:40 PM |
Chain adjustment | big twin grin | SV Talk, Tuning & Tweaking | 14 | 04-07-05 04:20 PM |
