Old 14-01-09, 09:58 PM   #21
Default Re: front sprocket
errrr dunno. Chains come with extra links anyway I think.
Old 14-01-09, 10:12 PM   #22
embee
embee's Avatar
You can put an extra tooth on the g/box on a curvey SVS with the standard chain, there's just enough rear wheel travel.
Mine has a 16T instead of the std 15T, and it's like Dizzy says. Feels more relaxed on long distance work. I always used to try for 7th gear, never do now. I don't go in for traffic light grand prix starts so I'm not bothered about that. Fuel economy doesn't change noticeably, maybe a mpg or 2, that's more down to riding style.
You just have to get used to the new gear ratios, 16/44 makes 5th almost exactly half way between 5th and 6th with 15/44. As long as you use the correct gear there's little real world difference, real world isn't like race-tracks where you can optimise gearing for the circuit.
If you want more relaxed, go 16T, if you want wheelies go 14T.
Old 14-01-09, 10:18 PM   #23
davepreston
cheers ive been offered a 16t front jt rear and o ring chain £80
Old 14-01-09, 10:21 PM   #24
Originally Posted by embee View Post
You just have to get used to the new gear ratios, 16/44 makes 5th almost exactly half way between 5th and 6th with 15/44. .
I notice the difference particularly around 30 mph in second. On Suzy you get 30mph bob on 5k, but you'll be doing 4.5k for 30 mph on Dave. I have to keep an eye a little more on the speedo, as its tooooo easy to creep over the speed limit, I look down and i'll be nearly at 35 mph, and it isn't screaming to be changed. ( I like to keep my noise down you see)
I can't be forgetting, if I've been jumping between the two bikes a lot....not hard at the mo, only one bike working again
Old 15-01-09, 12:16 AM   #25
What chain? JT sprockets are good stuff.
Not worth swapping sprockets depending on use no way, swapping a front sprocket is a right PITA and there's only so many times you can re-use the lock washer before you're playing with fire.
Old 15-01-09, 01:02 PM   #26
vardypeeps
I'm one up on the front and it's great! Brilliant for the motorway 80mph on the clock and it's just chugging away at 6000revs.
As for the corners I have not had any problems either still has the power there to put down on the exit.
Old 15-01-09, 06:50 PM   #27
Dangerous Dave
Nah, won't do much to the top end, since a stock SV won't hit the limiter in top on stock gearing anyway.
+ 1
Old 15-01-09, 07:07 PM   #28
You can order chains to whatever length you so desire.
Old 22-01-09, 09:10 AM   #29
TheStudent
I have a few questions about sprockets...
  • Standard rear is 45 iirc? What's the top speed with an extra two or three teeth?
  • Does the bike power wheelie with an extra two or three?
  • Is the bike noticably quicker, a worth while mod?
Old 22-01-09, 09:15 AM   #30
I've got 3 (from naked) up on the back, I've had 130 indicated on the naked. Yes it makes it easier to pop up, especially in 2nd. I like it, but you're turning a lot of revs on the motorway.
k6 front sprocket DOM B SV Talk, Tuning & Tweaking 12 18-04-09 07:12 PM
Front sprocket 14T maviczap Stuff Wanted 5 07-11-08 08:51 PM
14t Front Sprocket svdemon Stuff Wanted 3 26-11-07 02:13 PM
14T front sprocket Quiff Wichard For Sale - SV's and SV related items 4 25-11-07 05:07 PM
Front sprocket BILLY SV Talk, Tuning & Tweaking 3 04-09-06 07:45 PM
