Old 15-02-09, 10:24 PM   #21
Default Re: Thermostat Switch Help
Yes but why bother when you have no evidence if it works or not? Except for a garage telling you it doesn't, have they done the tests that the manual and common sense suggest? I doubt it.
Old 16-02-09, 12:43 PM   #22
warrenhewitt10
i just let the bike run there in my garage and it will heat up to about 99 degrees then drop to 88, then it will heat up again and the fan will come on breifly at about 108 degrees and keep the temp arround that! which means the switch is working?? or does it jus cut in at too high temp
Old 16-02-09, 12:46 PM   #23
Sounds fine to me TBH.
Old 16-02-09, 01:04 PM   #24
warrenhewitt10
oh ok ill leave it be then!! thanks for ur help!
Old 16-02-09, 06:14 PM   #25
2hys
i got sold a curvy switch for a pointy!! was told it was a modifcation!!! im going tomorrow to get a refund or money back. thanks guys youve helped two of us with one thread
Thermostat Housing cammy SV Talk, Tuning & Tweaking 4 24-04-09 09:29 PM
tip off switch antony SV Talk, Tuning & Tweaking 16 16-10-08 05:22 PM
U-switch Ed Idle Banter 9 27-08-06 03:15 PM
Switch Gear? Hogzi SV Talk, Tuning & Tweaking 0 08-03-06 07:22 PM
Switch Gear Hogzi SV Talk, Tuning & Tweaking 0 08-03-06 01:56 PM
