Old 04-03-09, 04:51 PM   #21
Luckypants
Luckypants's Avatar
Default Re: Checking my oil level
Originally Posted by punyXpress View Post
But is the generator ??
Well I know it is not the clutch cover, so the assumption was the generator..... and we know what assumption is the mother of.....
Can you correct me?
Old 04-03-09, 05:46 PM   #22
The engines are similar in that the RHS cover is over the primary drive, oil pump, water pump drive and clutch.
Generator/pickup is on the other side.
Personally I doubt the change in volume between hot and cold oil is significant.
Old 04-03-09, 06:47 PM   #23
Stu
Trinity
Stu's Avatar
Bugger, beaten to it.
I mean how's the poor guy going to find it if you call it a generator cover
Old 05-03-09, 08:31 AM   #24
Originally Posted by Biker Biggles View Post
Ive always found it doesnt matter much if its hot or cold as long as the bike is upright on level ground and you have left it a minute or so for the oil to drain down to the sump.What does matter is that you check it regularly and make sure there is enough oil in there to prevent it blowing up.
+1
People get fussed about this but it really doesn't matter. After the engine has been run it needs a short while to allow the oil to drain back the to sump, by which I mean a short while - one minute would be loads of time. Hot or cold as long as it's upright for a few seconds the level will be visible.
When you fill the engine with oil make sure you don't overfill it, that's the only time to be truly fussy about the level. Then as long as you swing the bike near upright and there's oil in the window it's OK.
Checking in Kalessin Idle Banter 15 15-01-09 11:27 PM
checking oil level, engine running or not ricky SV Talk, Tuning & Tweaking 7 23-05-08 06:17 PM
anyone wanna swap my hi level leo vine for a low level one spakmitten Exhausts 1 16-06-06 08:59 AM
anyone wanna swap my HI level leo vince for a low level one spakmitten SV Talk, Tuning & Tweaking 1 16-06-06 05:25 AM
Checking in Grifter SV Talk, Tuning & Tweaking 9 22-01-05 06:47 PM
