#21 |
Once you've got most of the air out, and good pressure at the lever, zip tie the lever back overnight, in the morning just crack the nipple open, which should purge the last of the air out
#22 | |
#23 |
Squeeze, open, close,squeeze open close
#24 |
So it needs to be squeezed all the way back before I open? (could have been going wrong here). I was going; open,squeeze,hold and close.
![]() Last edited by Dave20046; 06-03-09 at 08:07 PM. |
#25 |
Yes, to start with, that's how I found it.
mate held the lever against the bar, whilst I opened up the nipple. Gets through a fair amount of fluid to start with, then settles down, which is why you need to keep an eye on it. Otherwise it's back to square one
#26 |
Cheers. I might attempt to take a video and show you what it's doing....it just seems to blurt out fluid then nothing....
#27 |
If it blurts it out, then you need to close the nipple, then squeeze again.
That's why its a 2 person job. Sorry
#28 |
If I lived closer I'd come and help you, as bleeding brakes can be bloomin frustrating!
#29 |
You've still got air in the lines or air is entering the system somewhere then.
The only thing I can advise with brake bleeding is patience.... two pairs of hands also makes life easier to.
#30 |
Bleeding Brakes - Again | HopefullySoon | SV Talk, Tuning & Tweaking | 2 | 28-08-07 09:13 AM |
Bleeding Brakes (Bleeding Kits) | 21QUEST | SV Talk, Tuning & Tweaking | 8 | 20-06-06 05:31 PM |
Bleeding Brakes | sweepdoggydog | SV Talk, Tuning & Tweaking | 9 | 08-06-06 07:07 AM |
Bleeding brakes | Samurai | SV Talk, Tuning & Tweaking | 6 | 06-06-06 05:17 PM |
Bleeding Brakes | Moo | SV Talk, Tuning & Tweaking | 9 | 21-01-06 07:59 PM |
