Old 16-03-09, 09:11 PM   #21
Default Re: Low voltage relays
Originally Posted by tigersaw View Post
Kind of. The timer chip on the board needs a -ve going trigger, so depends on how the LED is driven, switched earth or switched +3v. If switched earth its straightforward, if +ve, then it needs a transistor added as an inverter.
Going to order the board and a mini siren and have a fiddle.
When I tested the green LED it was flashing (finding a signal) and the reading kept jumping up and down. When it found a signal it settled on 3.3V
Don't understand why it needs an inverter
Old 16-03-09, 09:16 PM   #22
tigersaw
tigersaw's Avatar
The LED could have a permanent +3.3V on the anodes, and illuminated by grounding the cathode - this is a common way of driving LEDs from IC's.
Equally it could have a perminant earth, and illuminated by sending +3.3V. In this case the 555 timer chip cannot be triggered directly, but adding a simple transistor inverter would sort it out.
Either way would read the same from a meter.
I have just ordered the timer circuit, I'll experiment when it comes.
RST Voltage Leathers DarrenSV650S Bikes - Talk & Issues 9 22-06-10 12:25 AM
Broken voltage Regulator MavUK SV Talk, Tuning & Tweaking 7 05-03-09 01:13 PM
Indicator relays Tiger 55 SV Talk, Tuning & Tweaking 14 19-01-09 08:36 AM
Relays mattc SV Talk, Tuning & Tweaking 2 24-09-08 05:53 PM
LED Flash rate relays... DF! SV Talk, Tuning & Tweaking 4 17-09-08 06:47 AM
