Old 30-03-09, 08:44 PM   #21
sinbad
Default Re: Does a slightly too lose chain sap power?
I doubt it saps power worth mentioning.
However, you've just raised the ride height, which means the swingarm is pointing at a greater angle downwards, meaning the chain will tighten more at full bump.
So, in an extreme case you tightening the chain means that at lets say half compression (full chain extension with normal positioning of spindle vs sprockets), you've just locked the suspension. Explaining your unexpected wheelying, as the power surge normally squatting the rear has now gone straight into the chassis!
I believe TL's were prone to this behaviour with the chain slack set as per the manual.
So, after adjusting the ride height, wind the rear preload as far off as it'll go (without removing the spring...), and use a ratchet strap or something to compress the suspension all the way to the bump stop, make sure the chain ends up with a little bit of slack all through it's movement. Otherwise I see another long wait at the side of the M6 for g33k boy and his flaco!
Good thinking, well explained. It seems very plausible to me, the chain aint gonna like it if that happens
Old 30-03-09, 08:59 PM   #22
punyXpress
punyXpress's Avatar
Could snap it ?
Now: Street Triple R
Old 30-03-09, 10:01 PM   #23
ThEGr33k
Originally Posted by punyXpress View Post
Could snap it ?
Aye
Looks like ill have to have a look intot that then Just in case... though its not really supprising that at full throttle the front came up
ha ha
You right about the Tl though mate...
groggy startup and lose of power with backfiring hbaden00 SV Talk, Tuning & Tweaking 2 19-06-07 08:09 PM
Lose (it's raining) gsv Bikes - Talk & Issues 8 17-06-07 05:21 PM
Anyone else here trying to lose weight? Razor Idle Banter 111 08-03-07 05:07 PM
Power Commander power graph print outs. JimPSV SV Talk, Tuning & Tweaking 19 27-11-06 09:39 AM
Where can you lose oil from? TSM SV Talk, Tuning & Tweaking 15 13-08-05 10:38 AM
