Old 30-03-09, 06:18 PM   #21
Default Re: Belkin wireless G+ router
thanks for that mate, when i do that it just says "connect to the unsecured network?" i click yes because the new router doesnt come with any passwords set.
then it says i'm connected but i'm not if you know what i mean? on your top piccy you have a "pc-then a router-then a globe" i have an "X" on the globe side.
Old 30-03-09, 06:22 PM   #22
John 675
okay back in the network and sharing center
this one :
click DIAGNOSE AND REPAIR and tell me what it says
Old 30-03-09, 06:24 PM   #23
John 675
sounds like your LOCAL ONLY..
hmm whats the model of the Belkin Router it should have a model number too, ill check the setup stages
Old 30-03-09, 06:30 PM   #24
DIAGNOSE AND REPAIR says it cannot repair the fault contact my internet service provider? but my nets ok cus it works on me netgear?
the belkin router just says BELKIN ADSL+2 MODEM WITH HIGH SPEED MODE WIRELESS G ROUTER version 1245uk
its an argos jobbie @ £47.99
Old 30-03-09, 06:33 PM   #25
John 675
okay give me 5 mins sounds like it has no settings installed or not done completely
dont worry pal we will get you sorted
Old 30-03-09, 06:34 PM   #26
Dan
Kwak,
Have you actually set your ADSL router up with the username and password to connect yet?
Old 30-03-09, 06:40 PM   #27
well i dont actually know how cus it didnt come up with a setup wizard? like i say it says i'm connected to the router but i dont think the router is connected to the net? i might take it into the garage in a mo and cut it in half with a hack saw
Old 30-03-09, 06:46 PM   #28
John 675
okay i just found this.. im looking for a virtual app for it so i can guide you better
Configuring the Router
The following setup process should be complete from one of your computers that have been connected with an RJ45 network cable, from the steps above.
Click Start, All Programs, Internet Explorer
In the address bar, type 192.168.2.1 and press the Enter key
By default the router has no password configured , leave the field blank and click Submit to login
The Routers setup wizard will now appear.
Select the correct options using information provided to you by your ISP.
Step 1.
Select the type of connection that your internet service provider uses.
Step 2.
This information is the login information unique to your own account. Enter your username and password in the spaces provided above.
Step 3.
The setup wizard will give a summary of the setting you have chosen, if these are correct click Apply to confirm and exit the wizard.
Note: please wait while the settings are applied to the router. A progress bar is displayed at the bottom of your web browser window.
Changing the SSID and default password
The SSID is an identification name for your Router. By default it is set to the manufacturer's name, 'Belkin'. You can change this to something else if you prefer. The SSID is the name of the workgroup you will connect to from your wireless computers.
To change the SSID, open the admin interface, as shown below:
Click Channel and SSID on the left setup menu
Enter a new SSID in the box labelled SSID
Click Apply Changes
Your wireless SSID has now been changed.
Default Password
To secure the router and to prevent unauthorised people making changes to the setup, you should change the default router password.
Login to the router admin pages, shown in the steps above.
Select System Settings
Leave the current password box blank and type your new password in the new password box and retype the password in the confirm password box
Click Apply changes to confirm.
Keep your password safe, you will need this password should you need to make any changes to your Belkin® router.
Old 30-03-09, 06:52 PM   #29
thanks john for that, BUT this is the bit i get stuck on "The Routers setup wizard will now appear.
Select the correct options using information provided to you by your ISP."
its says this in my paper instructions too but nowhere can i find a setup wizard?
i can log into the router like it says but i cant see anywhere for my details? only SSID changes and things like that, not actual isp user names and passwords? i'll have a play later but will offline obviously, will try to get back on later to let you know if ive set fire to it or not
Old 30-03-09, 06:59 PM   #30
John 675
... hmm if all else fails your ISP might be able to help but you can manualy configure ISP settings its just a set of numbers that tells the Router where to dial too, whose your ISP?
Which wireless router? StreetHawk Idle Banter 13 23-06-08 09:12 PM
what router? kwak zzr Idle Banter 39 14-11-07 05:21 PM
Any wireless wizards out there? Belkin router help needed Well Oiled Idle Banter 12 18-03-06 12:42 PM
Good range Router/Adsl modem/Wireless Access point? thor Idle Banter 16 08-02-06 04:16 PM
Beklin wireless router help Warren Idle Banter 17 02-02-06 07:32 PM
