#21 |
Ok, good to know. And shocks from other bikes like ninja and gsxr? Are they better/worse than aftermarket shocks made for SV? Are they usable on road? I suppose shocks from supersport bikes should be a bit on a stiff side, no?
#22 |
Captain Awesome
not only wheels, inertia is a mass's tendency to remain stationary resisting motion (from the word inert) - having a large mass higher up, making the centre of mass higher where it has further to travel when the bike gets leant over means it will not turn as quickly as a bike with a lower centre of mass, all other things being equal
as for putting GSXR suspension on an SV and them handling the same, not likely, the suspension on a GSXR has been designed for the GSXR, same with all the modern supersports - these days the manufacturers have to make the bikes handle to the limits of affordable tech to be competitive in the 600/1000 market. the suspension will be of better quality, and likely have a wider range of adjustable settings, so you'll find something that you like, and that's better than the stock SV, but a good aftermarket shock designed for the SV and it's frame geometry, rake, trail, COM and myriad of other variables will be better still
Official "Dumbass of the Year" 2011 (•_•) ( •_•)>⌐■-■ (⌐■_■) Deal with it... |
#23 | |
I'm going to order a new hagon rear shock today or tomorrow, since my current item is the OEM shock...10 years old, +36,000 miles. I don't beleive I need to change the fork springs (maybe the oil, it'll be a bit old by now) as I am quite light and don't really load up the front end Should I expect to feel a differance...? |
#24 |
If you do get Hagon shock, please write your impressions here, so I don't miss it
#25 | ||
![]() It might drop in, but for a bike to feel like it handles well it must be easy to stop it dropping when you need to! For that you need a low moment of inertia about the contact patch. That moment of inertia is a function of how much the thing weighs, and how high it is from the ground. Get some gixxer forks and shock, and throw £500 at them, and it will handle better than a new GSXR/YZF/C*R/ZXxR because it will be set up for you rather than some rough guess by the factory. Ride height yadda yadda, all this can be changed. I would guess that the CoG of an SV will be lower than the CoG of an IL4, half the cylinder barrells and heads are a lot lower to the ground, and there are only half as many.
#26 | |
Captain Awesome
the trick is to get a lighter bike with suspension suited to the weight of the bike + rider, then you'll have a planted and flickable bike, my KTM is an example, light as a feather but feels incredibly planted and stable on all surfaces because of the top shelf suspension adjusted to my weight...
Official "Dumbass of the Year" 2011 (•_•) ( •_•)>⌐■-■ (⌐■_■) Deal with it... Last edited by the_lone_wolf; 06-04-09 at 02:25 PM. |
#27 | ||
They will not behave as well as a shock built for SV and importantly built for the rider. But they are 1/10th the price. Quote:
Given some cash to blow I would take a SRAD 750 shock, send it to maxton or PDQ and get them to spring and valve it for me. Total cost about £280 and this will work, for all intents and purposes, as well as ohlins etc.
#28 |
Get Penske two way adjuster... £600. Well worth it
![]() With a decent shock set up right you'll be able to feel the grip and feel when its searching for it. Lumps in the road wont throw you out of the seat and the bike will be more "planted", mine actually feels better leant over now than sat up. ha. |
#29 | |
#30 |
Captain Awesome
understeering into or out of corners?
Racetech suspension question | Jackie_Black | SV Talk, Tuning & Tweaking | 71 | 12-09-08 04:15 PM |
Really quick suspension question | stewie | SV Talk, Tuning & Tweaking | 10 | 28-03-08 09:55 PM |
Car suspension question | Warthog | Idle Banter | 8 | 08-12-07 04:03 AM |
Easy suspension question | stewie | SV Talk, Tuning & Tweaking | 47 | 13-10-07 05:54 PM |
Suspension question | pilot | SV Talk, Tuning & Tweaking | 7 | 14-09-07 06:23 PM |
