#21 |
#22 |
Feel free to ask away... your wording threw me a little.
Above you put "how can a ZX10 shock be worse than curvy" Good/bad isn't just hard/soft. You could use a shock from a ZX10 (not the zx10r) from late 80s. It would be shoite! It's as much the quality of materials, the complexity of the valving arrangements etc. A shock from a 125 GP bike would probably be very under specced for the SV, maybe too soft or not enough travel/length. That doesn't mean it's a bad shock, as it's probably had hundreds spent on getting it set up... not a bad shock just not set up for an SV...
#23 |
Yeah my wording probably showed my confusion in its vagueness! never occurred to me about the linkage and swing arm making an influence but makes sense now.
#24 |
I feel i might have some searching to find those spring rates , going to put some posts on kwak forums.
EDIT I think i have found the spring rates on racetech.com #510 so should work. The problem i think i will have now is with fitting it , i didnt apreicate how much of an angle that resoir on the shock is at. Ill post some pics when i recieve the shock. ![]() Do you think i will have to move or alter parts of the bike to make it fit? Last edited by TheShadow; 09-04-09 at 06:27 PM. |
#25 |
Yeah, cut the front of the battery box out, get rid of the fusebox tray, space the battery up to fit.
#26 |
#27 |
If I remember right theshadow has a dodgy knee and I wouldn't want him to strain it again doing a runner
#28 | |
http://www.racetech.com click top right SEARCH ... and then "search spring rate" the spring rate is craftily hidden down the page rated in kg/mm. Most of the info on this forum is on lb/inch with figures 400-530 The page i've put uses kg/mm so just obviously * 2.54 to get to inches * 22 to get g/lb Last edited by williamturner1; 15-06-09 at 10:35 PM. |
ZX10 rear shock advice [yet again] | tonny006 | SV Talk, Tuning & Tweaking | 7 | 22-09-08 04:49 PM |
zx10 rear shock basic settings | Marksv | SV Talk, Tuning & Tweaking | 25 | 15-04-08 02:49 PM |
My 675 and treacles zx10 | Paws | Photos | 44 | 15-03-08 06:30 PM |
zx10 shock | skapegoat | SV Talk, Tuning & Tweaking | 10 | 20-01-08 10:02 AM |
ZX10-R '04 Rear Shock - Curvy Upgrade | pmapp | For Sale - SV's and SV related items | 5 | 01-10-07 09:02 AM |
