Old 05-05-09, 01:17 PM   #21
suzsv650
Default Re: Hid Xenons
www.HIDS4U.co.uk
Would recommend them
Use the code "strathy" when going through checkout and you'll get a decent discount, used to be 40%, think it's more like 20% now, if it still works that is...
Awesome Ta
Is this just one bulb and Ballast or two?
Old 05-05-09, 01:25 PM   #22
H4 fitments are a single arc with a movable shield to block light in a similar pattern to a twin filament H4 bulb
If you replace both bulbs on a pointy SV it's likely the the headlamp fuse will not be able to sustain the current draw at startup, so you'll need to contruct a basic relay loom to wire them directly (fused!!!) to the battery
i used the hids4u twin slim ballast kit on my K8 pointy.. no need for relay just put everything in the nose faring and plugged it up to the main connector..
no problems so far...
i originally used the supplied sticky pads to stick the ballasts to the inside of the air scoops but that lasted about 2 minuets then rattled around for weeks till i bolted the slim ballasts to the inside of the air scoops..
Old 05-05-09, 01:26 PM   #23
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
Originally Posted by suzsv650 View Post
That's just one ballast and one bulb
You need this one with twin H4 bulbs
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 05-05-09, 01:28 PM   #24
suzsv650
Yea thanks i was just going to post it up.. Bit pricy!
Old 05-05-09, 05:44 PM   #25
Grinch
They only seem to go as low as 5k, ain't that going to be a bit bright?
Old 05-05-09, 06:07 PM   #26
Bluepete
Bluepete's Avatar
That discount code works a treat!
strathy
Pete
Old 05-05-09, 06:55 PM   #27
MattCollins
Bright? Colour temp simplistically is the balance of Red Green and Blue. Daylight is around 5000-5500K under a mid day blue sky. Lower temperatures tend towards red, higher towards blue.
Best results with lighting come in the 4200-5000K range. In this range you will not notice a difference in brightness or light output, but will notice a slight shift in colour with the 5000K being slightly whiter, 4200K being slightly redder. 5000K is fine.
Also, I prefer the slightly warmer colours (cooler temp - don't ask) around 4200K because it makes it a little easier to discern critters in this part of the world.
Old 23-09-11, 08:00 PM   #28
maxinc
Manage to dig this thread up and ordered myself a 55w 5000k set. Hope they'll make a big difference since riding in the dark is not fun with standard bulbs, especially on twisty bits
Discount code still works BTW, thanks for that! Is now 25% off.
Old 24-09-11, 10:37 AM   #29
that's what i have on the new bike and they are the doggyz doodaz. as long as you remember to set the beam pattern afterwords all is fine and no one flashes you
i completely ripped the wiring apart in the nose cone and made a new loom for the gear with a new 10 way OEM block so i can remove the nose cone when ever i like without having to mess around with other wires. everything apart from the +&- cables are in the nose but the +&- are in the new 10 way block.
Old 25-09-11, 05:20 AM   #30
maxinc
Any chance you have a picture / more info on that custom loom? It looks to me that I may have to take the nose one out to fit them properly so any tips are greatly appreciated.
