Old 04-05-09, 10:37 AM   #21
Frank
Default Re: diesel fireblade
Originally Posted by ophic View Post
depends - old diesels would be fine. It used to be a common practice to put a bit of petrol through a diesel to clean it out. Modern common rail diesels get easily wrecked with quite small quantities of petrol. The fuel pump and injectors rely on the lubrication of the diesel fuel, and the petrol strips that away.
YC beat me to it.
ah I see.Long time since I worked on diesels.
Easy way out of the problem though...dont do it in the first place
Old 04-05-09, 06:02 PM   #22
-Ralph-
Will be fine, not much different to sticking in low octane petrol. Keep filling it every 1/2 tank for a few tankfuls, then let it run almost dry and refill with fresh petrol and change your fuel filter.
Old 04-05-09, 06:16 PM   #23
svtomo
if i was you id change the oil and filter. i put some petrol in my car that had a small amount of diesel in (probably 25:1 mix max) and it turnded the oil into wd40!!!
only reason i noticed was because the oil level suddenly came half way up the dipstick. the same also happened in my bosses car when he did the same, so id definatly at least check the oil level/thickness.
Old 04-05-09, 06:19 PM   #24
hovis
Originally Posted by svtomo View Post
if i was you id change the oil and filter..
how could it contaminate the oil?
Old 04-05-09, 10:47 PM   #25
Dave20046
Dave20046's Avatar
If you've bust a seal?
Then again if you had I'd guess I'd be tending to that first lol
Old 07-05-09, 09:18 PM   #26
svtomo
the diesel ends up in the so called blow-by gases which leak past the rings and ends up in sump/block area below the piston. when petrol gets past the rings it quickly evaporates through the breathers and ends up in the cylinder again, but diesel doesnt evaporate.
it doesnt happen in diesel engines as the fuel doesnt get injected until compression has already been achieved.
Old 08-05-09, 08:32 AM   #27
apparently a very tiny amount of diesel in a petrol engine won't harm.....wonder if thats why Pete swears blind the Dieselidici runs better??...and he keeps doing it..lol
Old 08-05-09, 08:46 AM   #28
keith_d
keith_d's Avatar
You might get some additional crap on your plugs too.
IIRC there are some components of diesel that don't combust completely in a petrol engine (that smoke you've been getting). If you're really paranoid you could take a look, but unless your bike starts running unevenly I wouldn't worry about it.
Keith. (Whose ex-girlfriend put a whole tank of diesel in the car!)
Old 08-05-09, 09:06 AM   #29
Dave20046
Dave20046's Avatar
God she would be an ex an' all
Old 08-05-09, 09:11 AM   #30
My brother cOcked up the turbo in his Seat Leon by putting the opposite of what should have been in there, the car was three weeks old, and cost him his left kidney to repair!
Fireblade / ZX9 or the like gettin2dizzy Stuff Wanted 4 10-04-09 02:26 PM
Fireblade, am i mad? mary Bikes - Talk & Issues 28 14-08-08 11:23 PM
Fireblade or GSXR1000 K7 kwak zzr Bikes - Talk & Issues 84 30-07-08 01:03 PM
07 fireblade. Quiff Wichard Photos 24 05-03-07 05:08 PM
fireblade for sale £900 hovis Idle Banter 39 03-11-06 09:48 PM
