#21 |
Ah sorry if that was misleading about the bearing, lets take it from the top;
Top yoke nut+ washer; SRAD Top yoke; SRAD Adjuster nuts x 2, washer; SRAD Bearing dust cover; SV Top bearing; TWF bottom bearing; standard SV (is the same as the SRAD) Bottom yoke and spindle; SRAD
#22 | ||
#23 | |
hey hey thats what iv been looking for next question what year of SRAD ? also do you know much about the axle or speedo seeing as i am using GSXR1000 K1 forks i take it i will need a gixxed1000 k1 front wheel/axel/spacer washers will i be able to use the standed sv speedo ?
Curvy With Lots Of Bits ...
But Still More To Come ![]() |
#24 |
I would not expect it to matter what year of SRAD you use. Out of preference I'd go for the latest one I could find.
The SRADs were 96-99* *for the 750, 600 as we know it was only out in 97. '96 600 was the one in double cradle frame. Weighed about a million tonnes and was pointless compared to a slingy 750. Because you're using SRAD yokes, you need to use an SRAD axle, otherwise it may be the wrong length. Wheel. I would need to check, maybe SRAD, maybe K1-> Hopefully SRAD, because they're cheaper, and they match the rear.
#25 |
haven't the foggest... best person to ask would be northwind or YC also do you know much about the axle or speedo seeing as i am using GSXR1000 K1 forks i take it i will need a gixxed1000 k1 front wheel/axel/spacer washers yes and no.. this depends on the yoke spacings... will i be able to use the standed sv speedo ? yes.. but you will need a hall effect sensor in place of the SV's wheel mount sensor and magnets in the discs.. there is another way but you would have to ask northwind or someone who has done a rear sensor mount |
#26 |
Bibio if you could measure the space between your discs then that would tell us about the wheel (I can nip downstairs and measure SRAD)
#27 | |
link for rear speedo http://www.socalsvriders.org/forums/...threadid=10167
#28 |
#29 |
SRAD (according to my cheap $hit vernier caliper)
130mm between discs measuring to inside 25mm inner diameter of spindle 32mm spindle diameter at fork base.
#30 |
according to my veryneers the spacing inside disc face to disc face is 127.5mm outside will be +10mm for disc thickness this would give us 137.5mm outside
you have to remember that the GSXR1000 K1-2 discs have a recess machined in the inside face bolt hole area of .5mm |
curvy forks | husky03 | For Sale - SV's and SV related items | 5 | 29-10-08 07:10 PM |
Curvy forks wanted. | skapegoat | Stuff Wanted | 1 | 22-01-08 07:29 AM |
Gsxr Forks On Curvy | CHICKENSTRIPS | SV Talk, Tuning & Tweaking | 1 | 18-07-07 05:45 PM |
curvy sv forks fit k4 ??? | daddy_sperm | SV Talk, Tuning & Tweaking | 2 | 24-04-05 07:12 PM |
Conversion to GSXR1000 front forks ? | Powergaard | SV Talk, Tuning & Tweaking | 2 | 21-01-05 12:12 PM |
