Old 29-05-09, 09:25 AM   #21
arenalife
Default Re: Anyone know anything about cars/wheels?
Expect reduced acceleration, more noise, harder ride and more fuel consumption, if they're important to you.
Old 29-05-09, 10:21 AM   #22
Dave20046
Dave20046's Avatar
In regards to what and by how much?
Suspension or wheels. And by how much would I have to alter each before this is an issue.
Old 29-05-09, 10:37 AM   #23
muffles
In my experience you're not likely to notice anything other than a harder ride, I don't think it will be loads harder - changing the springs will affect that more.
Old 29-05-09, 10:38 AM   #24
Dave20046
Dave20046's Avatar
Originally Posted by jimmy__riddle View Post
Not quite right, it's width (mm), aspect ratio (%) then wheel diameter (inches).
The 'thickness' of the tyre is labelled as a percentage of the width.
Avoid spacers, wheels with the correct fitment/offset will not need spacers. Spacers are a quick way to wear out wheel bearings, sometimes depending on ally offset they can be ok, but proper fitting wheels dont need them.
heres the spec for a mk4 golf
PCD : 5x100Offset : 30 to 45Bore : 57.1Fittings : B 14x1.5
from alloywheels.com
Is the offset the 'stud diameter'?
Lookin at a few now
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=260418391062
They look good and are 16's just wondering if I'd need to lower to suit
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=250429906956
they look ok and look like a guaranteed fit. Hopefully look better on a black car too.
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=300317410750
think they'll look good but I'd need to refurb them
hmmm
Old 29-05-09, 10:39 AM   #25
Jamiebridges123
Yeah those 17" in the Red one would probably look pretty good on your black one..
Old 29-05-09, 10:43 AM   #26
muffles
Lookin at a few now
hmmm
Offset is the distance from the hub face (the bit that goes flat up against the wheel face on the inside) to the centre line of the wheel (the centre line of the wheel being the line you'd cut if you wanted to chop the wheel in half to make 2 thinner wheels).
Old 29-05-09, 10:45 AM   #27
jimmy__riddle
no, tried to explain in words but it never made sense so i will paste a link in
http://www.driverstechnologyassociat...eel-offset.htm
clearly shows why spacers should not be needed with the correct rims
edit; muffles is better with words than me! lol
Old 29-05-09, 10:47 AM   #28
fizzwheel
fizzwheel's Avatar
You dont "need" to lower it, the car will function perfectly adequately on its standard springs ( which is what it was designed to run )
But it will "look" better if you lower it as it'll reduce the gap between the tyre and the wheel arch, you'll also gain in terms of handling as the lowering springs will also in most likelyhood be stiffer which will reduce the amount of bodyroll and crispen the handling, the trade off you get is that the ride is harder.
You might also notice the car tracks poorly across bad or steeply cambered road surfaces due to the wider tyres as well. I used to notice it in my golf which had a 40mm drop but was still on the standard 15" rims...
I'd be also inclined to go with standard silver coloured alloys anything else can look chav, black, polished or white can look good but only on the right car.
The others are right, if you get the right offset you shouldnt need spacers. I'd try to avoid going down that route if I were you.
Old 29-05-09, 10:53 AM   #29
Dave20046
Dave20046's Avatar
ahh that's what I thought it's just on the listings the stud diameter value kept coming up as 100 and confused me.
Cheers everyone
Old 29-05-09, 10:56 AM   #30
ophic
ophic's Avatar
...anything else can look chav...
so you can lower a car and fit big rims without it looking chav?
Silver SV650SK3, Fuel exhaust
Why do red cars... glsuk1970 Idle Banter 10 09-05-08 04:54 PM
4 wheels good, 2 wheels better Dysparunia Bikes - Talk & Issues 6 30-11-06 07:37 AM
BMW cars............ simple simon Idle Banter 50 13-09-06 01:16 PM
Been looking at Cars fizzwheel Idle Banter 49 27-01-06 08:48 PM
BMW cars............ S.D.SV Bikes - Talk & Issues 49 08-01-70 12:46 PM
