#21 | |
Spot the numpty! ![]() ![]() That'd make sense why I wasn't getting a reading. It should be fine then as I was getting continuity on each wire individually. Batter on multimeter ran out. Will need to get another one tomorrow. Then I'll re-test it AFTER I've plugged it back in ![]() I'm going to have a cig and go to bed now, hanging my head in shame haha |
#22 |
Knob faced knobster
![]() Nah I don't do electrics, too much hassle
2011 Speed Triple 1050 |
#23 |
#24 |
OK. Bought my own multimeter today. Resistance at the ICU is also 189 ohms for the pulse generator coil (having reconnected the connector block
![]() Any other suggestions for me to try testing? Cheers, Josh |
#25 |
Well I'm baffled.. Cleaned the contacts to the ICU with contact cleaner and then sprayed in some WD-40, plugged it back in and it fired straight up.
How odd |
#26 | |
Well done with ach'em 'fixing' you're bike ![]() |
#27 | |
Is RMS basically an average? How would I have tested that? Trouble is (reason I hate intermittent faults) that now it's working as it should, the readings will appear fine, no? |
#28 |
Aye if its working then theres no problems..
![]() What does Haynes give their values in? I do electronics, and I can't remember what multimeters read in ![]() Vrms is a route mean square value. No I hardly understand it, all i know, Vrms = Vpeak/root2 |
#29 |
I thought RMS was calculated by squaring the values, taking the mean of that and then routing the answer. Anyway, I don't have a way to test that here AFAIK
#30 |
AFAIK?
Naaa its peak/root2 Going out on the bike since you fixxed it? ![]() |
Poor Running Engine? (Curvy 99) | vardypeeps | SV Talk, Tuning & Tweaking | 11 | 20-03-09 11:26 AM |
Curvy running funny :( | Dave20046 | SV Talk, Tuning & Tweaking | 24 | 30-09-08 08:52 AM |
Bad starting, poor running, 2000 Curvy. | jtrent90 | SV Talk, Tuning & Tweaking | 15 | 01-07-08 02:55 PM |
grrr headlights | yorkie_chris | SV Talk, Tuning & Tweaking | 2 | 09-12-07 05:17 PM |
Various Running Problems - Solutions - Curvy SV | Hooligan | SV Talk, Tuning & Tweaking | 2 | 05-05-06 08:45 PM |
