Old 17-07-09, 06:59 AM   #21
Default Re: Oil pressure bypass valve.
Steel bolts into nice soft (and thin) aluminium stubs - if the bolt's goosed the clutch centre usually is too.
Old 17-07-09, 07:07 AM   #22
MattCollins
Fair enough. Thanks for the explanation.
Old 17-07-09, 11:39 AM   #23
jambo
jambo's Avatar
Go on, tell us, what torque were you trying to tighten those (long, spindly) bolts to. Go on. Go on go on go on.
Nick, you're adoring public awaits a response.
I very nearly did the same thing years ago, mis-read the manual and was about to set the weedy little coolant drain bolt to 23Nm when my brain chipped in and said "That's a huge ammount for that little bolt, lets just back up and read that again".
Jambo
Old 17-07-09, 11:49 AM   #24
ThEGr33k
I did check a couple of times... I probably got it wrong.
Fortunately it was the bolt that gave way and not the aluminium. The threads are good, but then they are M6x25mm bolts so it had a lot of weedy aluminium to pull against so I was luck in that respect.
For the record I tried 30nm. Thought thats got to be wrong so I just did them hand tight + 1/4 turn and thats when one popped off. I dont know my own strength it seems. All in I think I was quite lucky!
Ear Pressure irnbrumad Bikes - Talk & Issues 15 03-06-09 10:28 PM
Eyeball - Beverley Bypass DarrenChay Pennine Massive 0 22-04-09 09:07 PM
Was that you on the A1 western bypass? toonyank Bikes - Talk & Issues 1 05-06-07 10:36 PM
Eyeball Hayes Bypass FG1 Idle Banter 0 16-10-06 08:19 PM
Sobering - A647 Staningly Bypass - Leeds 454697819 Bikes - Talk & Issues 0 28-01-06 06:14 PM
