Old 27-07-09, 01:10 PM   #21
drag
Default Re: Front end chatter
Originally Posted by custard View Post
oddly - you may find you have too much rebound on the front and the forks cant extend quick enough so they pump down and then bottom out which causes the chatter. conversely this may be not enough compression...
but hey if its fine going in, just get the front wheel off the ground on the way out - hey presto no more chatter
Fully you should mention this, i'm prob 14 + stone @ the mo and i've never come close to getting the front to lift on her, even now with the 160/162.5 jets.
Must not be dumping the clutch enough at high rpm
Old 27-07-09, 04:47 PM   #22
custard
keep trying
have you set the sag for your weight?
Old 27-07-09, 05:12 PM   #23
drag
The back sag was set yup, and the front end is a bit more then 10mm left of travel, i'll sort that soon enough
Old 27-07-09, 05:37 PM   #24
custard
hmmmm... have just been trying to sort mine out so here are the could be's as i see it
could be the mis matched tyres.
could be too much front rebound so forks arent extending quick enough (bounce the front end and see how quick they come up, more than a second is too much i think)
too little rear compression so rear squats and front comes up (may exacerbate too much front rebound)
Old 27-07-09, 05:59 PM   #25
drag
What if i cant bounce the front, i.e it's really stiff, and only moves a mm or three :S
Old 27-07-09, 06:58 PM   #26
are you sitting on the bike with the front brake on while you are trying to bounce it?
put a cable tie on the stanchions and take the bike for a blast, then come tell us how much it is travelling down the stanchions.
Old 27-07-09, 08:14 PM   #27
drag
Post sat evening spin, about 80 + miles
sorry about the glare ..
Old 27-07-09, 09:17 PM   #28
custard
no idea. im out. other than stronger springs
oh and the reboud compression and tyres.
buy an r1, i have no idea
Old 27-07-09, 09:41 PM   #29
ok, the travel on the forks looks good so the spring is about the right setting. so if you are sitting on the bike and you cant move the front end by bouncing it then your compression setting has to much 'H' (not reactive enough) turn the compression 2-4 clicks to the 'S' (more reactive) then take it for another spin. if you feel that the front is to 'plush/wollowy' turn the compression to the 'H' 1 click at a time if it still feels to 'hard' then dont be scared to turn it further to the 'S'.
once you have your compression set then you can set your rebound.
Old 27-07-09, 09:54 PM   #30
drag
Compression is on top right ? when i sit on the bike witht he brakes pulled, i can push the forks down, but it's not really much @ at all, i'll see if i can get a video of it 2 morrow maybe .
Crash.NET - Stoner subdued by chatter. NewsBot News 0 27-04-09 08:50 AM
K3 front brake lever, Front indicator (RH), Front Mirror(RH), Bar End (RH) leegriffiths128 Stuff Wanted 0 23-07-08 09:11 PM
Crash.NET - Chatter at Kawasaki... NewsBot News 0 13-07-07 05:20 PM
Front end chatter on heavy braking - wtf? thor Bikes - Talk & Issues 16 18-05-07 10:18 PM
Crash.NET - Nakano 'still suffering chatter problems'. NewsBot News 0 24-02-07 04:44 AM
