Old 02-09-09, 01:39 PM   #21
custard
Default Re: Making my own heated grips controller
Originally Posted by lee67 View Post
pointy s has an accessoery socket in the loom up behind the headlight
would there happen to be one on the thou?
Old 02-09-09, 08:09 PM   #22
embee
embee's Avatar
Originally Posted by Alpinestarhero View Post
.. Embee, I think I understand what you're on about, but im not completly certain...maybe you can PM me with what you mean in a more numpty-friendly langauge? ....
I'll post something here, others with more electronickery knowledge can add/correct/expand as necessary.
The Maplins "speed controller" is just a variable mark-space device, in other words it switches the output on and off rapidly for varying proportions of time, the output is at full supply voltage when it's on. I don't know what frequency it runs at, for a simple resistive load like heated grips it doesn't matter, but it's often in the kHz range. The relative proportion of on/off is termed the duty cycle (usually in percentage terms. e.g. 50%) or mark-space ratio or similar, the "on" pulse width is "modulated", hence the term "pulse width modulated" or PWM.
In this manner it controls the power the device gets supplied with, it doesn't rely on "wasting" energy in order to do it.
You'd need to measure the resistance (or current demand) of the grips to decide whether it would be adequate.
The current rating of this unit is probably determined by the output device, and I guess it could be uprated by either substituting a larger device (transistor/thyristor?) or using it as it stands to drive an additional one. This is where my knowledge runs dry I'm afraid.
If you are adept at wielding a smouldering iron you could probably rig the control pot remotely from the board, making it neater and possibly improving weatherproofing.
It'll probably be cheaper/easier to buy a purpose made unit, the better ones will be this type of control circuit anyway.
Old 21-09-09, 11:19 AM   #23
Dave20046
Dave20046's Avatar
You ever get one sorted alpine?
As it's getting colder and I have hotgrips fitted to the bike I'm thinking I may aswell get them working. My old controller blew just as I bought the bike, so need either a DIY one or a proper one.
Old 21-09-09, 12:02 PM   #24
Alpinestarhero
Right, forgot about this thread.
I complained to oxford customer services, who sold me one of the other analouge controllers at a discounted price (15 quid instead of 22)
If you are unhappy with your heated grips controller, moan to them. They may be good to you and help you out.
I took heavily into acount what embee said about how the controller works (it phases the switch on/off/on/off, not just constantly on and dumping the excess electrical energy as heat at the resistor) and oxford helped me out
So, i should have warm toasty hands this winter, hurrah
However, as a side project, i may look into making one, and then if it works I can make a guide and people can then use that guide and improve.
Old 21-09-09, 12:08 PM   #25
fastdruid
fastdruid's Avatar
Hmm, when my Oxford controller died I got another controller for 5 quid from the bike show the other year. As it's also failed[1] I think I'll try and get another one from there!
Especially as at this rate of healing it'll probably be December before I get to ride a bike again. :-/
Druid
[1] Ish, you can sometimes get it to come on.
Old 21-09-09, 12:38 PM   #26
ophic
ophic's Avatar
Just wire in a switch. Hands get cold, turn on. Hands get too hot, ride faster.
Silver SV650SK3, Fuel exhaust
Old 21-09-09, 12:56 PM   #27
Dave20046
Dave20046's Avatar
That's my thinking at the mo
Can anyone foresee any issues with this?
Less bulky then the crappy controllers too.
Old 21-09-09, 01:02 PM   #28
ophic
ophic's Avatar
it was a serious suggestion - just make sure the switch can handle the current. My grips are usually off or set to MAX. No point in owt in between, imho.
Old 21-09-09, 01:07 PM   #29
Dave20046
Dave20046's Avatar
I know , I was being serious. I was considering it the other day just wondered if it made any odds. Can you get switches with an LED to indicate they are getting power? I don't see why not...
Old 21-09-09, 01:16 PM   #30
ophic
ophic's Avatar
you can, although i'd be more worried about getting a properly waterproof switch.
R&G Heated grips gerbrox Ancillaries 9 27-07-09 03:00 PM
Heated grips Daywalker Bikes - Talk & Issues 3 17-02-09 01:08 PM
Heated Grips? smidge26 Riding Gear 41 09-11-08 01:06 PM
New oxford heated grips controller Alpinestarhero SV Talk, Tuning & Tweaking 21 30-09-08 03:00 PM
getting heated grips off -more help please!! jenni SV Talk, Tuning & Tweaking 21 07-12-06 05:53 PM
