Old 23-09-09, 09:09 AM   #21
Dave20046
Dave20046's Avatar
Default Re: Reduce Force of Throttle Return Springy Thingy
Quite right
Old 23-09-09, 09:55 AM   #22
May I suggest a new/lubed set of cables. Curvy doesn't have a heavy throttle when everything is healthy.
Old 23-09-09, 12:03 PM   #23
boot
Would that not cause the opposite effect of what I'm trying to achieve?
Old 23-09-09, 02:24 PM   #24
Kinda, but if your hand is getting tired then it's more likely that excess force needed to move it anywhere is the issue.
Old 23-09-09, 02:32 PM   #25
boot
Yep, fair and interesting point.
Old 23-09-09, 11:28 PM   #26
TightRS
TightRS's Avatar
Originally Posted by boot View Post
Hi Folks,
My throttle returns with quite some force, is there a way to reduce the force it springs back with? Obviously I want it to return properly, but not require a tight grip all the time, which gives quite a bit of aggravation on longer journeys.
When I adjusted the throttle free play with the cable adjusters (lever side) on my SV650S pointy, setting them incorrectly would make it return slower or stick. I dunno if you can ride it like that though.
SV650S K5
GSX-R Shock, R6 Throttle, Oxford Hot Grips, R&G Crash Guards, Hugger, Fender Extender, Radiator Cover, Mirror Extenders, Stebel Magnum Horn, DL Handguards, Philips X-treme +80%, Denso Iridium Plugs.
TightRS is offline   Reply With Quote
Crash.NET - Swine flu fears to reduce Spanish GP fans? NewsBot News 0 29-04-09 02:40 PM
Crash.NET - Swine flu concern to reduce Spanish GP fans? NewsBot News 0 29-04-09 12:40 PM
Throttle return cable? Stevetmanchester Stuff Wanted 0 20-10-08 10:27 PM
throttle return cable 01 sv650s SV Talk, Tuning & Tweaking 4 24-11-06 12:24 PM
KBC force air Grinch Helmets 7 04-03-05 07:12 PM
