#21 | |
*However I don't really know where'd do that stuff. Would it be any old car motor factors or would I need something a little more specialist?
#22 | |
You can get the automotive relay at Maplin (40A works fine too). ![]() |
#23 |
I've just fitted a new set of hotgrips, they have the digital controller with the three rubber buttons. All fitted as per the book, direct to battery as it will cut itself out below 11.5v, so shouldn't flatten the battery.
Switched it on, fine. 30% power showing. Fine. Push the power up button, nuffin. No change in power output. Pulled it apart, put it together again, the same, 30% and no more. Called M&P, "Oh yeah, there are lots of problems with that unit, return it and we'll replace it" Here's hoping the next one wont be a Friday afternoon special too! Anyone had this fault? Pete ![]()
https://www.facebook.com/pete.philli...04?ref=tn_tnmn |
#24 |
Well to let anyone with a problem with these know I've now wired the controller directly to the battery and although I haven't used it since, I did rev it up and it appears to work just fine, no idea why though
![]() Seems strange to me it matters where they are wired to, I assume they get the same amount of electrikery from the ignition circuit or direct from the battery ![]() Nick |
oxford heated grips relay | AndyBrad | SV Talk, Tuning & Tweaking | 6 | 23-07-09 06:35 AM |
Oxford heated grips | Clone | Bikes - Talk & Issues | 6 | 18-09-08 04:21 PM |
Fitting Oxford heated grips | carty | Bikes - Talk & Issues | 22 | 13-01-08 10:46 PM |
Oxford heated grips | SDMF | Thames Valley | 3 | 14-12-07 09:59 PM |
oxford heated grips | didge | Photos | 0 | 12-09-05 07:16 PM |
