#21 |
A valid point, if you have access to only one pc download the drivers from dell first.
#22 |
I can copy the files over to HDD2 using command mode. I have the 80gb drive that came with the machine and a 250gb one I bought in addition.
By the way - I think this may be the root cause of the problem. The two are mounted right on top of each other and spin at the same nominal speed but are a fraction of an rpm different and this gives a vibration that increase and decreases about every 3 seconds. I think that vibration isn't doing the disks any good so I intend to change the way they are mounted when I've sorted this lot out. Again thanks for the advice. what a great bunch the orgers are . Cheers Keith |
New Hard Drive - Noise? | 600+ | Idle Banter | 3 | 30-03-09 06:17 PM |
Which External Hard Drive? | Miss Alpinestarhero | Idle Banter | 48 | 10-02-09 08:12 PM |
hard drive problems | sv_rory | Idle Banter | 25 | 21-12-08 03:32 PM |
New hard drive required | Stu | Idle Banter | 23 | 09-12-06 02:37 PM |
pc hard drive question | will | Idle Banter | 6 | 15-05-06 02:38 PM |
