#21 |
fantabulas
not when they are as squeaky as mine...
My Flickr photos |
#22 |
no but at least it stops you sneaking up behind innocent folk
#23 |
I have a wardrobe in the shed where all of my riding kit is stored. It has extraction fans in the top and vents plus a low power heater element in the base which is not used often. At this time of the year my feet get soaked every day and my preference is heavy (>90%) wool socks.
#24 | |
![]() Cheers Mark.
#25 |
plastic bag over sock
Then put newspapers inside the boot (will soak up the water) |
#26 | |
The point of that post was more about the drying method as per the thread subject line. When I pull my boots on I want them dry. A box with a good air flow, heated slightly (not hot) if temperatures are low, will dry boots quickly enough if the excess water is drained away. Cheers |
#27 |
I see your point to an extent, but with today modern materials I would have thought the extremes were just what it was developed for ?
But you're right it's getting away from the OP question. I don't really suffer from this as these days not only do I use robust liners I have 4 pairs of boots to rotate should the need arise , however as far as drying goes, I've found any leather suffers if dried to quickly, my bathroom has underfloor heating through quite heavy tiles and is left on all year round, a side effect is a very gentle heat perfect for drying wet leathers and boots. Cheers Mark.
Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming, 'Wow! What a Ride! Last edited by rictus01; 21-11-09 at 05:07 AM. |
Cleaning and drying MX boots | lukemillar | Bikes - Talk & Issues | 4 | 21-07-09 09:12 PM |
Crash.NET - Stoner quickest at drying Sachsenring. | NewsBot | News | 0 | 17-07-09 02:20 PM |
Crash.NET - 125: Marquez takes debut pole at drying Le Mans. | NewsBot | News | 0 | 16-05-09 12:40 PM |
VAT.. help! quickly! | valleyboy | Idle Banter | 6 | 31-07-06 11:41 AM |
