View Poll Results: How do you reduce your speed from a top gear?
Brake hard and kick the gears down in one go to match the new speed 15 25.86%
Brake then down shift using the gears to slow the bike 40 68.97%
Slowing down?? wtf's that. Blat it all the way (p.s. this is not an option - don't click here) 3 5.17%
Voters: 58. You may not vote on this poll
Old 11-12-09, 01:55 PM   #21
Amanda
Default Re: Riding Style Question
critical imo, good post.
Yeah, great experience when you get it wrong!!!
First time on the other halfs Gixer, thought process went like this.....
'ooo this is fast, innit
'hmmm maybe a bit too fast
'better slow down for the corner now
'maybe thats still too fast, bit more brake
'Arrrgghhhh, why is the bike still upright,hedge looks close, must steer, Oh yeah try getting off the brake numbnuts!!!!! phew bugg4r me
Old 11-12-09, 01:57 PM   #22
wattyfred89
wattyfred89's Avatar
roll off the thottle, at about 5-6th rpm you can drop a gear, with blipping the throttle (the thought of not blipping the throttle makes me cringe lol) then whilst doing this brake at the same time ( takes practice)
as said above brake in straight line , then whilst taking the corner have a gear with decent amount of rev's so if you are going too fast there is no need to brake, just roll back the throttle. (safer)
wattyfred89 is offline   Reply With Quote
Old 11-12-09, 01:59 PM   #23
ThEGr33k
Remember brake in a straight line before corner entry, get all your slowing down and gear changing down done before you turn the bike for the corner or roundabout. Once you have the bike turning if you have judged everything right you should not need to brake or change gear again until you have applied the throttle on corner exit.
IMHO
Id say critical this time of year when grip isnt so abundant
Id say that in summer you can practice a bit of brake trailing
Old 11-12-09, 03:15 PM   #24
I don't use the brakes in this situation, as I've already observed said roundabout.
Engine braking and downshifting, with a bit of that there blipping stuff. I make the SV do the work, and my pads last forever!
Gradually roll to a controlled stop, without even touching the brake til I get to the line, or indeed pass over it as I get straight on the bout.
Make sense? TBH, just go and practise.
Old 11-12-09, 03:42 PM   #25
metalangel
Depends on what I'm coming up on and the speed I'm going. I don't see any harm in staying in whatever gear I'm in until I'm almost at idle revs before clutching in and changing down, as it means I'm getting full use of the brakes and not faffing with individual downshifts while also trying to stop.
But if I'm not trying to stop but might need to, engine braking and then change into an appropriate gear when the traffic in front starts moving/lights go green.
Old 11-12-09, 04:20 PM   #26
whatever you do make it smoooooth (smoothness is less tiring) if your head is constantly doing the 'noddy dog' then your riding wrong. your riding style should also be dictated by conditions.
Old 11-12-09, 04:26 PM   #27
Spiderman
Where the hell am I?
Spiderman's Avatar
If i'm in a rush, late for something and need to keep my average speed up then i do option 1.
If not then its forward planning, engine breaking and suitable gears.
Blipping when going down thru the gears becomes second nature after a while and its very usefull i find in this type of weather. Dont like feeling the bike squirm under me on cold greasy roads and the throttle blip stops that.
Old 11-12-09, 04:35 PM   #28
Fizzy Fish
I tend to scrub off the speed via advanced planning and downchanges TBH.
I only really use the brakes if I'm in hooning mood, and even then braking happens after some of the speed has already been scrubbed off via the above. If I'm braking a lot, the gearchanging usually comes alongside that. Sometimes I'll drop down 2 gears at a time, but not more that that.
Old 11-12-09, 04:51 PM   #29
Vindaloo
Vindaloo's Avatar
Using brakes or gears to slow down is for girls. I use walls and ditches. Far more effective and saves £££s on replacing worn brakes, too.
Adrian
Vindaloo is offline   Reply With Quote
Old 11-12-09, 05:04 PM   #30
ophic
ophic's Avatar
One small piece of advice if you're used to blipping.
If your engine cuts out, use the brakes. Mine did once. I pulled over and gently slowed down changing down the gears... or that was the attempt. In fact I broke traction on the rear with every downshift. Nice straight road, fortunately.
Silver SV650SK3, Fuel exhaust
Moving on to IL4 - Change in Riding style? rich_r Bikes - Talk & Issues 25 19-06-07 02:18 PM
Thank you (Riding style) scorpion Bikes - Talk & Issues 1 17-04-07 08:59 AM
What a difference Riding Style makes to MPG!!! SpankyHam Bikes - Talk & Issues 43 06-07-06 04:23 PM
Rev it! Riding style questions. Bud Bikes - Talk & Issues 11 24-03-05 10:22 PM
Rev it! Riding style questions. cotwbs SV Talk, Tuning & Tweaking 10 04-01-70 05:29 AM
