Old 14-12-09, 06:39 PM   #21
ThEGr33k
Default Re: Damaged piston (VFR400)
Originally Posted by Alpinestarhero View Post
Does it sound like the engine is turning over at all?
Suspect sprag?
Did you try to bump it?
Old 14-12-09, 06:40 PM   #22
EssexDave
Yeah I bump started it. Was that a mistake?
Old 14-12-09, 06:41 PM   #23
The fact that as per your OP it started fine and rode home (did it feel OK?) suggests there's bugger all wrong mechanically.
Old 14-12-09, 06:42 PM   #24
EssexDave
Even after the bump start it rode fine.
Old 14-12-09, 06:46 PM   #25
shifter
I'm finding it very hard to believe that anything valve or piston would prevent it from starting, especially when you have 2 seperate heads and didn't hear anything go bang.
Have you checked all the basics, fuel air and sparks etc?
Old 14-12-09, 06:47 PM   #26
EssexDave
I've checked sparks and fuel. I tried starting it on the reserve too just to be sure.
And yes, I did check the killswitch
Old 14-12-09, 06:48 PM   #27
shifter
Now I'm leaning towards a starter fault as well
Old 14-12-09, 06:50 PM   #28
ThEGr33k
No, not at all tbh
This is interesting. If the starter spins like mental, does it sound like there is any load on it? If you go and try to turn it over does the actual engine turn over? If not then sprag clutch could have gone... Im not sure if this happens on these bikes.
Old 14-12-09, 06:53 PM   #29
EssexDave
Erm, well I don't have the bike at the minute as the shop does. But I don't think it sounded like there was any load on it. But I can't remember, I've be around quite a few different bikes past 2 weeks with different problems. Bad memory.
Old 14-12-09, 07:16 PM   #30
beabert
Did he put oil down the spark plug hole and do a second compression test?
For Sale: VFR400 NC30 EssexDave For Sale - Other Bikes and General biking items 2 13-10-09 08:10 AM
VFR400 breather hose EssexDave Bikes - Talk & Issues 5 22-09-09 08:28 PM
Honda NC30 VFR400 BigFootIsBlurry Bikes - Talk & Issues 12 30-04-09 12:35 AM
FOR SALE - VFR400 NC24 D Reg geodudeft For Sale - Other Bikes and General biking items 2 10-04-09 05:25 PM
Honda VFR400 arc123 Bikes - Talk & Issues 12 20-04-05 11:24 AM
