#21 | ||
When you close them up around a decent size wire (like the orange out of the ignition), you chop through a load of the conductors, and create an entry point for any salty water to cause corrosion. Which will make this worse, and the next thing you know the insulation melts from the high current in the narrowed point, shorts against the headlight mounts and the next thing you know you've smoked the headlight glass from the inside...
#22 | |
![]() ![]() The bike I've got at the moment has a few extra bits on it and inside the headlight bowl is just that bit scary...plenty of those scotchlock things in there ![]() To be honest, never really liked the things myself and was quite shock when I found out how stuff had been wired in. Ah well, here's hoping .... ![]() Cheers Ben |
#23 | |
#24 | |
![]() Like i said before about the scotchlocks, ive used them and ive never had a problem with them but taking the time to solder is a much classier finish. |
#25 | ||
Even if the grip's fuse is of a lower rating than the fuse upstream of it, it may well take longer to pop than its supply fuse - if that's the main fuse the bike dies. Much of this may seem academic, but I do electrical stuff, (in a variety of circumstances, vehicles included), for a living and I assure you that stuff that can go wrong does, the small cost of a relay, and the little time required to fit it adds a negligible amount to the job of fitting heated grips.
#26 |
scotchlocks, are they one fits all (wires sizes?) I am needing to fit a second hand PC3 so wondering if that is a good item to use...
#27 |
No there are couple sizes
http://www.vehicle-wiring-products.e...ectors.php#tap P.S that site also sells some very nice weatherproof connectors, soldering kit and crimp connectors to do the job properly...
#28 | |
Which sort of weather proof connectors are you meaning? I cant really solder as its a tiny thin wire that goes to the TPS, cutting that back or basically doing anything to the wire means a lot of work... I wonder if Id just be able to get a connector that Dynojet actually supply with the PC3's? (Like I mention its for the TPS tap) |
#29 |
Remove the tab out of the connector and solder a thin signal wire around the crimp?
#30 |
Oxford heated grips and symtec heated grips | Alpinestarhero | Ancillaries | 18 | 25-01-10 04:43 PM |
What's up with the ignition? | arcdef | SV Talk, Tuning & Tweaking | 14 | 17-12-08 11:15 AM |
wiring up oxford heated grips | hovis | Bikes - Talk & Issues | 23 | 07-11-07 08:01 PM |
Wiring | yorkie_chris | SV Talk, Tuning & Tweaking | 21 | 28-08-07 09:56 PM |
Wiring K4 | pittsie | SV Talk, Tuning & Tweaking | 0 | 20-07-06 06:06 PM |
